hard to steer
Old 01-22-2007, 09:15 PM
hucka1a's Avatar
hucka1a
hucka1a is offline
hard to steer
my 81 F150 is extremely hard to unless your going 40mph or more. My powersteering pump is full of fluid. I'm wondering if the pump maybe bad or if it's something else, like the steering box?
Old 01-22-2007, 09:25 PM
taisa899's Avatar
taisa899
taisa899 is offline
check for a kink in the powersteering lines. I had my pump off and when I put it back on the truck was hard to steer. Apparently when I took it off I ended up kinking the metal line that runs to the rubber one.
Jim
Old 01-23-2007, 03:40 AM
srercrcr's Avatar
srercrcr
srercrcr is offline
The pump is probably shot. Theyre reliable within limits. Still have my original pump after 170,000 miles.
Old 01-23-2007, 08:36 AM
Duncan10's Avatar
Duncan10
Duncan10 is offline
I have seen where the king pins were partially siezed in the IBeams on one side only and it was very hard to steer or turn at low speed Jack up the truck and see if it is tough to turn with no weight on the front end. If your truck has been pulled out of a ditch or whatever someone may have hooked part of the steering parts.
Old 01-29-2007, 07:37 PM
Archion's Avatar
Archion
Archion is offline
Also check for binding on the steering column, ie: sagging cab mounts etc, that could also be an issue.
cassell1
02-19-2015 11:48 AM
Ford4X4ingboy
38
10-03-2011 11:56 AM
landdesigns
2004 - 2008 F150
07-24-2010 04:22 PM
yasky69
1997 - 2003 F150
01-14-2006 08:10 PM
dazman
1978 - 1996 Big Bronco
06-08-2004 11:30 PM
Quick Reply: hard to steer
