Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 01-22-2007, 09:15 PM
hucka1a's Avatar
hucka1a hucka1a is offline
Garage is empty, add now
hucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to allhucka1a is a name known to all
hard to steer
my 81 F150 is extremely hard to unless your going 40mph or more. My powersteering pump is full of fluid. I'm wondering if the pump maybe bad or if it's something else, like the steering box?
__________________
Huck
Early 99 F250 with parts from Clay, Scott, Roland, Cory, JD, Pete, Christian, Neal, Jim. You could say "Built by Ford, Modded by the Brotherhood"...
  #2 (permalink)
Old 01-22-2007, 09:25 PM
taisa899's Avatar
taisa899 taisa899 is offline
taisa899 is gaining momentum as a positive member of FTE.taisa899 is gaining momentum as a positive member of FTE.
check for a kink in the powersteering lines. I had my pump off and when I put it back on the truck was hard to steer. Apparently when I took it off I ended up kinking the metal line that runs to the rubber one.
Jim
__________________
anybody wanna race???
  #3 (permalink)
Old 01-23-2007, 03:40 AM
srercrcr srercrcr is offline
srercrcr is starting off with a positive reputation.
The pump is probably shot. Theyre reliable within limits. Still have my original pump after 170,000 miles.
  #4 (permalink)
Old 01-23-2007, 08:36 AM
Duncan10's Avatar
Duncan10 Duncan10 is offline
Duncan10 is starting off with a positive reputation.
I have seen where the king pins were partially siezed in the IBeams on one side only and it was very hard to steer or turn at low speed Jack up the truck and see if it is tough to turn with no weight on the front end. If your truck has been pulled out of a ditch or whatever someone may have hooked part of the steering parts.
__________________
Duncan
84 F150 4X4
80 F150 4X4
76 F250 4X4
98 Explorer Limited 4X4
08 F250 SD 6.4l 4x4 CC Lariat 3.73 gears
08 Suzuki C90T 1500 cc Cruiser
and a bunch of parts trucks 49 Merc 1 1/2t 65 F100 80F100 x2
  #5 (permalink)
Old 01-29-2007, 07:37 PM
Archion's Avatar
Archion Archion is online now
Trained Parts Monkey
2002 Ford Excursion
My Garage
Archion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud ofArchion has much to be proud of
Archion.Uberpimp PartsGuyMatt mvose OVC Archion
Also check for binding on the steering column, ie: sagging cab mounts etc, that could also be an issue.
Tags
1998, 1999, 2001, duty, explorer, exursion, f150, f250, ford, hard, series, steer, steers, super, truck, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
