97 f150 blowing instrument cluster fuse - Ford Truck Enthusiasts Forums
Old 01-08-2003, 01:29 AM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Old 01-08-2003, 10:19 PM
leighann48 leighann48 is offline
leighann48 is starting off with a positive reputation.
I have a 97 f150 4.6L automatic and something in the gear shifter keeps blowing the fuse that controls my instrument cluster. I think that the problem may be something with the overdrive transmission button in the end of the shifter. Can anyone help me PLEASE???
Old 01-08-2003, 11:54 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Pull the steering column covers off and look for rubbed through wires at the base of the shifter.
Old 01-09-2003, 01:16 AM
I tried this and couldn't find any. Is it possible to take the shifter off?
Old 01-09-2003, 02:32 AM
AjRagno AjRagno is offline
AjRagno is starting off with a positive reputation.
I've been through this on all 3 of our 1997-on Ford Automatics with the column shifter. It's most likely the O/D wires. It looks like Ford doesn't use quite enough length.
-Pop the cap off the O/D switch with your finger nail.
-Pull the O/D switch out and unplug the 3 wires (Note the correct terminals).
-Put the transmission in 1st gear.
-Pull back on the leather boot at the base of the lever and remove the pin to release the shift lever. After that, you can pull the shift lever off the wires.
One of the wires has probably frayed. You'll need to soilder in a new one and wrap it with tape or put a plastic sleave over it to keep this from happening again.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 11:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 08:56 PM
Tags
1997, 97, blowing, blows, cluster, f150, fuse, fuses, gear, guage, instrument, problems, put, shifting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
