4 wheel lock problem on 2001 F150 SuperCrew
I've got a 2001 F150 SuperCrew 5.4, As of late when It wont go into 4Low if you do get it into 4low you have a very hard time getting out. you can move the **** from 4H to 4L nothing happens or from 4L to 2H and nothing happens. But sometimes it will work, everything was working fine until yesterday. Any ideas.
The truck needs to be in park or neutral to shift in & out of 4 low.
Or maybe the actuator on the t-case is bad.
1997 F350 PowerStroke,5 Speed, 4X4,36 Inch Buck Shot Mudders, Strait Piped, Chiped, Propane Injected, LUK Clutch, Reverse Shackle Kit
thegreatgate
1997 - 2003 F150
15
09-13-2014 02:04 PM
