Firing order 2001 Ford F150 4.6 litre - Ford Truck Enthusiasts Forums
Old 01-21-2007, 05:04 PM
rjmojica rjmojica is offline
rjmojica is starting off with a positive reputation.
Question Firing order 2001 Ford F150 4.6 litre
What is the firing order for a 2001 Ford F150 4.6 litre
Old 01-21-2007, 05:25 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
Firing order 1-3-7-2-6-5-4-8, distributorless ignition
Old 01-21-2007, 05:28 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
The firing order is usually stamped on the intake manifold.
New engine LostFade 2004 - 2008 F150 2 07-04-2015 09:34 PM
Firing order 2001 Ford F150 4.6 litre rjmojica New Member Introductions 1 01-21-2007 02:19 PM
looking for a IAC valve coho Alberta Chapter 2 06-23-2004 11:20 PM
4.6 5.4 differences 78fordman Modular V8 (4.6L, 5.4L) 2 02-19-2004 10:33 AM
Firing order on a 4.6 Multipierce Modular V8 (4.6L, 5.4L) 2 10-05-2003 04:08 PM
Tags
1997, 1998, 1999, 2001, 46, 46litre, 97, engine, f150, fireing, firing, ford, order
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
