You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm new to this type so excuse me for being a rookie but my F350 4x4 won't go into 4 wheel drive unless I get out and take them out of auto and put them in locked position and when I have it in lock mode it seams to work like it's in auto mode,when I put the switch on the dash in 2wd, it seams like it's only driving the back wheels,any help would be nice
Your ESOF system is working as designed when you put the hubs in the 'LOCK' position. Keep in mind that when you put the switch to 2HI...the transfer case disengages. The front hubs are still locked, but the front drive shaft is not engaged at the transfer case. (hope that makes sense)
The real issue is the ESOF hubs in 'AUTO' are not working. Could be the vacuum lines, vacuum actuator, or the hubs themselves. If the hubs...then they need to be replaced and that is a Dealer only part...at about $250-$300 each.
Hope this helps...
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
Your AUTO hubs have failed. Possibly a vacuum leak.
Basically the hubs connect the front axle to the wheels.
Basically the transfer case connects the transmission to the front drive shaft.
Having the hubs in MANUAL/LOCK position does not determine the truck is actually in 4x4 mode. For the truck to be in 4x4 mode, 2 things must occur: the hubs must be locked in and the transfer case must be engaged. If one of these 2 does not occur, then the 4x4 system does not work. Since your hubs are now manually locked in, the dash switch determines the mode of 4x4 or 4x2. This part is normal.
Thanks to you guys, I found a vacuum hose that came off at the bracket before the axle and put it back on with a clamp.Took me 10 minute and cost almost nothing.This couldn't have came out any better thanks to your help.I will be useing this forum again.THANKS again friends
Yet another FTE success!
biz
__________________
ok just a quick question. I have a manual 4x4 on the floor. Can i lock the hubs without engaging the 4x4 and drive off road till stuck. Then engage. If yes will it cause any problems ? is it a bad idea?
You can do this easily, especially on the trail. I wouldnt drive on dry pavement for long, i always unlock mine because i have heard of a some front hubs making a whining noise after locked due to being on dry pavement for long. I used to lock them before hittin any mud but now i think its more fun to just be lazy and try to power out in two wheel drive.
YES...you can certainly put the hubs in the 'LOCK' setting...and not engage the transfer case (4x4) until you are stuck in 4x2. However...it might not be a good idea depending how stuck you get. Because putting in 4HI or 4Lo does not guarantee getting out...all the time. Sometimes it is the momentum that carries you through.
IMHO...as you see the conditions worsen...just engage 4Hi or 4Lo as needed...and do not wait until stuck in 4x2.
biz
__________________
