Transmission Whine
Transmission Whine
Okay, so here's the deal. I just got my 78 F150 Ranger Lariat last week. (pics in gallery) First truck I've ever owned. I don't know a lot about trucks or engines - a little about aircraft engines becasue I'm a pilot - and I know a pistion engine is a piston engine - put the planes I flew didn't come with a transmission...:-)
The Lariat is in fantastic shape. The only things I know right now that need attention are an accelerator pump and an incessant transmission whine.
The whine sounds like a turbine spooling up ... or .... down. The whine occurs mostly in the lower gears and usually stops when I let up on the accelerator. The guy I bought it from said it's had that whine ever since he's had it. He's a Ford mechanic and re-built the 351 on it. I did a little research and is it possibly a gearbox issue?
Can anyone enlighten me on this type of whine and what needs to be done to fix it. Or ... is it just a live with it annoying tick that comes with older trucks?
Thanks guys and any gals out there...:-)
Tamara
Tamara
Do you hear the whine....
when stopped or in netural? If you hear it only while driving, you might want to check your rear end fluid. I just replaced my whiney, worn syncros 5 speed which masked the whine that went to a chuckle noise in the rear end. The trans would whine above 30 mph and the rear end did the whine below 30 mph. Now I have a whole new drivetrain and the silence is defening.......chris3
Halloran1
20
03-22-2012 09:24 PM
5.4L to Freedom
1999 to 2016 Super Duty
12-16-2010 05:51 PM
