Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-21-2007, 07:44 AM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Garage is empty, add now
Gun-Driver is starting off with a positive reputation.
Whats the problem
I just cooked 50 gal. of glycerol for 2 1/2 days @ 180-190* and only recovered about 15gal of methanol. The 25 gal. or so I cooked on my first batch I recovered 13gal. around 50%. Why the drop in yield, I set everything up the same.
Any ideas???
  #2 (permalink)
Old 01-21-2007, 08:18 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Any ideas???
Sounds just right. 15 gallons/ 50 gallons is 30 percent, the best I've ever done was 36 percent. I think the 13 gal/ 25 gal was a fluke, did you test that batch for the amount of Methanol? You might have carred over some water with it.........
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 01-21-2007, 10:32 AM
Gun-Driver's Avatar
I thought people were getting 50% recovery. The first batch might have been a little more than 25 gal it was the first time with my tank and I didn't mesure the amount going in. The glycerol was in a bunch of cubes, some filled more than others.
Another question?? When the glycerol is cooking my sight tube has mostly a clear liquid in it with the brown glycerol at the bottom, but when I drain it it all comes out brown-no seperation. What's the clear liquid??
  #4 (permalink)
Old 01-23-2007, 08:37 PM
1935 Ford pickup
Most likely a small amount of methanol, which recombines with the glycerol when you drain the tank.
__________________
  #5 (permalink)
Old 01-23-2007, 09:05 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
So are you cooking the glycerol in your processor? The reference to the sight tube sounds like an appleseed....
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #6 (permalink)
Old 01-24-2007, 10:57 PM
Gun-Driver's Avatar
Yes I'm using my apple seed type cooker with a condenser unit attached to the hotwater out side of the tank.
  #7 (permalink)
Old 01-26-2007, 09:22 AM
Interesting. I presume you are applying vacuum to the tank as well? If so, how much will it stand? I've read that H2O tanks can't handle much vacuum without collapsing...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
