You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 6.9 myself and I was seeking viton lines and o-rings to replace those on my truck so I could run bio and I got a hint from someone on these forums but i forgot who and they told me to simply go to my local hardware store and buy some of that cheap braided clear line hose they sell there and use that instead. It is the BEST thing I have ever done for my truck. It is bio-diesel safe and its clear so you can check and see if you have air in your lines or you can see the quality of fuel running through your lines. Its AWESOME.
Wow, that does sound good but it brings to mind some questions. DO you know how it will respond to heat and/or other oils? Do you know the material name?
__________________
Ron In Oregon
'99 F250, V10, Man. Trans., 4 Door Ex. Cab, 4X4
'00 Ranger 4.0, 5 Sp. 4 Door Ex.Cab, 4X4
man i sure do not know the material name. you can call your local hardware store though they will know exactly what you are talking about. they sell this stuff in a clear hose and a clear braided line, but I was told to get the clear braided. I have the stuff running from both of my tanks and then all throughout my entire engine. its great cause I can take a peak anytime and see if I have air in my lines (i have had problems with this in the past) so it makes it real convenient. i have been running bio now for like 8 months and the lines are still crystal clear they havent even clouded up or anything.
i was told not to use the clear stuff, because eventualy itll wear away with b100, but if it alright, ill have to go get some, did you also use it for your return line?
FWIW, I've had a piece of the clear stuff without any reinforcement in it hooked up as the return line between the #1 injector and the fuel filter since I bought my truck. No signs of the fuel doing anything to it at all.
FWIW = For What Its Worth
...and a few more common shorthands are...
IIRC = If I Recall Correctly
LMAO = Laughing My *** Off
ROFLMAO = Rolling On Floor Laughing My *** Off
Quote:
Originally Posted by DNewton
2. so ill be fine if i hook up the braided vinyl clear line hose for all return lines and fuel lines?
Seems like it. My piece of clear tubing is only 4 months old - which is why I said FWIW. Dunno' about the long-term yet....
well, if its cheap, i dont mind having to replace it.........but then again, i havent had to replace all the hoses yet, so i dont know how much of a pain it is......
OK, well, you've gotta replace all the o-rings under the return caps (the piece on the injector where the return hoses attach). If you don't they will leak air once you disturb them.
The o-rings are a profile # 111. Anyplace that sells butyl rubber o-rings can sell them to you for a few cents apiece. Each injector needs two. When removing them, remove the bottom one first. With the top one still in place the bottom one will "roll" right over the top one and not fall into the groove. Likewise, when installing them, put the top one into its groove first and then the bottom one will just "roll" right on over it and down to the bottom groove.
Assemble the hoses and return caps as an assembly and install them that way after the o-rings are in place. Put a little oil, grease, or vasaline on the o-rings after they are in place and it will make pushing the caps down over the new o-rings a LOT easier.
