Ranger 3.0L Component Locations
Old 01-20-2007, 02:25 PM
Bob Ayers's Avatar
Bob Ayers
Bob Ayers is offline
Hi All, I had to take a picture of the location of the oil pressure sending unit on a 3.0L today, and I thought while I was at it, I would take pictures of the
other "popular" components:
Oil pressure sending unit (analog, not "switch"):
DPFE sensor:
IAC valve:
MAF sensor:
TPS sensor:
Coolant temp sensor (gauge):
Coolant temp sensor (PCM):
Old 01-20-2007, 03:46 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Great pics and labels Bob, should help out a lot of people. IIRC you changed out the original metal DPFE with the plastic one, right?
P.S. Sure looked like a beautiful moring in Durham, NC today...
Old 01-20-2007, 03:54 PM
Bob Ayers's Avatar
Bob Ayers
Thanks Joe! Yes, I had the infamous P0401 code!!! Let me know if you can think of any other photos that would be of help, I know you are the best
for technical documentation!!!!
Old 01-21-2007, 08:10 AM
wendell borror's Avatar
wendell borror
wendell borror is offline
Thats cool Bob, could you do a 4.0 sohc ha ha, great photo's and information, I allways said you were handier than a button on an outhouse door ha ha.
Old 01-21-2007, 09:44 AM
pgw85706's Avatar
pgw85706
pgw85706 is offline
This is great Bob. Very helpful.
I hate to show my lack of knowledge and to trouble you further but.....
1. Could you translate the multi-letter abrevations into the words they stand for.
2. I should would like to see a picture of the M5OD and t-case fill and drain plugs.
Old 01-21-2007, 10:05 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
MazdaRangerGuyInSTL is offline
IAC - Idle Air Control
EGR - Exhaust Gas Recirculation
DPFE - Differential Pressure Feedback Exhaust (AKA EGR Position Sensor)
PCM - Powertrain Control Module
FORD - Fix or Repair Daily
ABS - Anti-lock Brake System
SRS - Supplemental Restraint System
TPS - Throttle Position Sensor
BCM - Body Control Module
IAT - Intake Air Temperature
CTS - Coolant Temperature Sensor
OBD - On Board Diagnostics
HYUNDAI - Hope You Understand Nothing's Driveable And Inexpensive
MAP - Manifold Absolute Pressure
BFH - Like Duct-Tape, Fixes Lots of Things
TCC - Torque Converter Clutch
Old 02-06-2007, 03:02 PM
CMOS's Avatar
CMOS
CMOS is offline
Bob,
As a noob to the 3.0L I thank you for this thread. Bookmarked for future reference!
CMOS
Old 01-31-2020, 03:02 PM
W Glenn's Avatar
W Glenn
W Glenn is offline
13 years later
Is it too late to thank you for the very helpful pics? Let me know when you go into landscape photography.
Old 10-14-2023, 07:58 PM
Bud Armour's Avatar
Bud Armour
Bud Armour is offline
1st Gear
Thumbs up Thanks
DPFE sensor:
IAC valve:
MAF sensor:
TPS sensor:
The pics really helped me.
Needed to differentiate between the temp sensor for the gauge and the temp sensor for the computer.
WIREPULLER
23
05-24-2021 04:19 PM
matrix311
2017+ Super Duty
21
02-11-2018 11:29 PM
crestronwizard
41
11-06-2017 06:19 PM
nullop
1999 to 2016 Super Duty
09-19-2015 03:04 PM
Bob Ayers
21
09-20-2006 07:40 PM
Quick Reply: Ranger 3.0L Component Locations
