Keyless Entry Module - Ford Truck Enthusiasts Forums
Old 01-20-2007, 12:29 PM
art flynn art flynn is offline
art flynn is starting off with a positive reputation.
Does anybody know where the keyless entry module is located on a 2004-2007 Ford F150 Crew Cab? Thanks.
Old 01-20-2007, 03:39 PM
the4by4freek the4by4freek is offline
the4by4freek is starting off with a positive reputation.
It is located behind the rear seat back. Do a search for rear seat back removal and it will tell you how to remove it. If you need the code go to the dealer and ask them if they can pull it for you. Mine did it for free..... it takes about 30 seconds this way!
Old 01-21-2007, 08:58 AM
Thank you. I need to find this module so I can get the code off of it so I can use the key pad on the door in the event I get locked out. The code is supposed to be written on the module. Thanks again for the info.
Old 01-21-2007, 11:15 AM
You are correct. The code is on the module. Did you just purchase the truck? If so bring it back to the dealer and have them pull the code for you. Most dealerships will do this free of charge if you purchased it there. If it is not a Ford dealer, then have them foot the bill for the code retrieval!
Old 01-21-2007, 12:15 PM
sgt82nd sgt82nd is offline
sgt82nd is starting off with a positive reputation.
Here's a link to the excellent article with pics (if you want to do it yourself).
http://www.ford-trucks.com/article/i...2006_F150.html
Old 01-21-2007, 03:56 PM
Thanks sgt82nd for the info. I like to do most things myself rather than go to the dealer. That info is going to make the job a lot easier. This is my first time on here and you people are the best. Thanks again.
Old 01-21-2007, 08:42 PM
Baggerdude Baggerdude is offline
Baggerdude is starting off with a positive reputation.
Art ...
The owner's manual has a section on the key pad. Also, there should be a 'key pad' card in the owner's manual that has the code that was given with the truck.
The owner's manual gives you directions to clear the pad and enter your own numbers. I believe only 5 are allowed.
If not, you can also see the module that others are speaking of.
BAGGER
Old 01-22-2007, 08:34 AM
BAGGER, Many thanks..............
remote keyless entry module F250 99 RMA New Member Introductions 1 02-11-2008 04:12 PM
Neal 97 ono_55 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-27-2007 07:45 AM
Factory keyless entry module location? MikeD916 Ranger & B-Series 3 05-03-2004 07:47 AM
Keyless entry code for 2003 Explorer danzadra Explorer, Sport Trac, Mountaineer & Aviator 5 09-27-2003 04:51 PM
'97 Explorer, keyless entry 1997-2006 Expedition & Navigator 5 08-25-2002 10:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
