Cats? - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Cats?
Old 01-20-2007, 09:24 AM
ChevmaninaFord ChevmaninaFord is offline
ChevmaninaFord is starting off with a positive reputation.
Cats?
I talked to a muffler shop here in Greenville, NC and he said removing the back cats would trip the rear O2 sensor, what about the pre-cats??(I dont know what theyre called) Would removing these cause me to not pass inspection under the new laws?
Old 01-20-2007, 10:20 AM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Yes if you remove them you will fail the inspection. I can't say about the location of the cats best I can say talk to someone who does inspections.
Old 01-20-2007, 10:40 AM
InstantGrits InstantGrits is offline
InstantGrits is starting off with a positive reputation.
The easiest thing to remember is if it was on the truck from factory it has to be there for NC OBD2 inspection.
Old 01-20-2007, 12:44 PM
Well thats no good, was Ford having trouble passing emissions because Chevy and Dodge only have one pair?
Old 01-20-2007, 12:55 PM
Truth be known I only know from the inspectors side. Not sure why its done that way. Sorry man, I aint much help.
Old 01-20-2007, 01:14 PM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
ncfirefighter46 is starting off with a positive reputation.
i have changed some on chuckyes (chevy) that had pre and aft. o2 sensors, and yes you will get a code if they are not there and the engine will run crappy, best thing to do on a 96 and newer is to buy the pefromer exhaust made for the o2 sensors, they do make them and high out put cats and do some mods and programming to the truck to get the high output if that is what you are looking for. if it is just changing the exhaust, then buy the kit mad to replace the factory a lot of compines offer them and they are not really that cheap but it is the right way to go and pass the OBD II
Old 01-20-2007, 01:55 PM
I've changed my exhaust enough, I was just trying to find out why the Fords were different, thanks for all the help. My Dynomax Bullet is pretty loud, I just wish it would idle louder.
Old 01-20-2007, 01:59 PM
Quote:
the before and after o2 is to make the engine run more cleaner, it gives more info to the computer to control the fuel air ratio: and if you wnat a louder exhuast you may be able to just change the muffler to a glass pack or just gut the muffler i have done that
Old 01-20-2007, 02:38 PM
The Dynomax Bullet is straight through, it does have ceramic insulation in it similar to a glasspack.
Need diesel tech moebdick South Carolina Chapter 0 01-23-2011 12:41 PM
Greenville Swap meet Bob at warsaw 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 04-05-2008 10:48 PM
Who can help/do the balls joints in my truck? one_wicked_element Michigan Chapter 29 01-29-2008 05:58 PM
Anyone near Wagner or Greenville SC? 92F150Flare South Carolina Chapter 6 06-02-2007 10:04 AM
Get Together in Greenville March 31st autospecial South Carolina Chapter 54 04-04-2007 08:55 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
