heater control valve location - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-20-2007, 06:41 AM
fawey1 fawey1 is offline
fawey1 is starting off with a positive reputation.
I am trying to locate the heater control valve on my 1997 4 cylinder 2wd ford ranger. Any advice and/or pictures of it would be appreciated.
Old 01-20-2007, 10:37 AM
Tiggie's Avatar
Tiggie Tiggie is offline
Tiggie is starting off with a positive reputation.
On the passenger side of the engine. Follow the heater hoses from the firewall and you'll come to it.
Old 01-21-2007, 10:07 AM
I followed it but don't see what the picture shows, could it look different? Mine is a 4 cylinder automatic with air?
Thanks,
Ken
Old 01-21-2007, 12:47 PM
Tiggie's Avatar
That's what mine looked like on my '95 4-cyl, with are, but's a manual.
Now that I look, it could also look like these:
There is also a chance it could have been elminated by someone. I'm not completely sure about the HVAC system on the Rangers, but many cars don't use a heater control valve, they just let the coolant into the heater core all the time.
Old 03-31-2007, 03:47 PM
98range 98range is offline
98range is starting off with a positive reputation.
I have a 98 ranger with the four port valve. A vacuum line connects to the valve. What makes the valve open or close? Does it close off the coolant into the heater core when closed?
Old 03-31-2007, 04:03 PM
Tiggie's Avatar
Quote:
The vacuum makes it open/close (not sure which). Depending on the position of the temperature selector and climate control selector (the thing you turn to A/C, defrost,etc), vacuum will be applied.
It does block the coolant from the heater core when closed.
Old 03-31-2007, 04:08 PM
Why then is it hot either on a/c or heat? Only max a/c is it cool but not cold air. I did the fix on the blend door but don't think it worked. I guess I just want to know which control shuts the heater valve so no hot coolant enters the heater core.
Thanks for your answer.
Old 03-31-2007, 10:16 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
The valve is open all the time except when MAX A/C is selected.
Old 04-01-2007, 09:46 AM
Tiggie's Avatar
Mine doesn't open until you cut the heat on. In the OFF position, I'm sure it doesn't open.
Old 04-01-2007, 10:07 AM
Rockledge's Avatar
Quote:
You are correct. The valve is also shut (cutting off the hot coolant to the heater core) when OFF is selected. I should have been clearer on that.
Old 04-01-2007, 03:25 PM
Thank-you for the answers. I might try and cut the plenum under the door to see if I can remove door that must be broke.
Old 05-18-2007, 06:41 PM
Pinhead-227 Pinhead-227 is offline
Pinhead-227 is starting off with a positive reputation.
I know this thread is kind of old, but I'm having the same problem. The heater control valve on my '98 Ranger isn't shutting off the heat. Just like 98Range and Rockledge's. Did you guys get this fixed? How?
Old 05-18-2007, 06:45 PM
Rockledge's Avatar
Quote:
Are you saying you can't get any cool air even when you turn the temp. control **** all the way to the blue (cold) area? If that's the case, then you have a blend door issue. The blend door is not the same thing as the heater control valve.
Old 05-18-2007, 09:22 PM
Yes I got mine fixed. I bought a new blend door from Rock Auto Parts for about $9.63. I cut a hole in the bottom of plenum to remove old door. I drilled a 3/4" hole with holesaw to lift out the door.(dimple in molded plenum that held old door)
I then used a 1/2" copper cap to a 3/4" long piece of copper pipe and soldered it to a 9" piece which I screwed to the bottom of the plenum.
The copper cap holds the bottom of the door in position as the piece of plastic I drilled out. If you want to talk by phone PM me with your # and I will explain in more detail.
Old 05-18-2007, 09:51 PM
Sounds like a cool fix. I'm in the process of trying the "Blend Door Fix" with the actuator. One problem, though...
What do I do if I drop my ratchet behind the actuator? Mine was held down with 3 screws, and when trying to get to the rear one (front of the pickup) it fell and I can't reach it...
HEATER CONTROL VALVE MarauderV8 1997-2006 Expedition & Navigator 2 12-17-2014 01:44 PM
49' Heater valve johnfin1 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 10-16-2014 01:09 PM
heater control valve troy676 6.0L Power Stroke Diesel 4 02-19-2014 07:47 PM
Heater control valve hodges710 1997-2006 Expedition & Navigator 8 10-22-2011 08:52 AM
Heater Control Valve C-700 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 01-19-2009 11:17 AM
Tags
1997, 1999, 2003, 99, control, f450, ford, fors, heater, located, location, navigator, picture, ranger, v10, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
