Help with High Beams on Headlights
I've tried it all... I have a weird situation. I have a 2000 F-150 SCAB 4x4 5.4L Lariat 7700. My headlights work... However if I need to flash my brights (push the turn signal forward) there are no brights... If I switch to brights completely (pull turn signal back) My headlights go off completely, no brights at all and no light at all. I've replaced the fuses associated with the headlights especially the brights. The brights require a 20A fuse which I replaced.. Any ideas? I'm stumped. Everything else works. The Fog Lamps, the DRL Autolamps, everything but my brights.
Help. Wicked winter weather is headed back into Oklahoma and I need some LIGHT!!!!!!
