Where can I find my PATS module? - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 01-19-2007, 04:25 PM
eagerinsight eagerinsight is offline
eagerinsight is starting off with a positive reputation.
Working on installing a remote starter, I have a PATS bypass but I'm not sure where to find it so I can wire my bypass? For remote start I have to wire to my tachometer, can I just wire it to one of my ignition coils?
Old 01-23-2007, 08:45 PM
MDELANO MDELANO is offline
MDELANO is starting off with a positive reputation.
12V|yellow, grn/purple |+ | ignition harness
STARTER |red/lt. blue |+ | ignition harness
| IGNITION |blue/lt. green |+ | ignition harness
| SECOND IGNITION|gray/yellow(2nd acc)|+ |ignition harness
ACCESSORY |red/black |+ |ignition harness
| SECOND ACCESSORY| black/green |+ | ignition harness
POWER LOCK| pink/yellow |- | keyless module *2
POWER UNLOCK| pink/green *5 |- | keyless module *2
LOCK MOTOR| pink/black | | drivers kick panel
UNLOCK MOTOR| red/orange | | drivers kick panel
DISARM DEFEAT| pink/orange | | passengers kick panel
PARKING LIGHTS | brown | + | at light switch
PARKING LIGHTS | | | |
HEADLIGHTS| | | |
DOOR TRIGGER |lt. blue/white *3 |- | keyless module *2
DOME SUPERVISION| black/lt. blue |+ | passenger kick panel
TRUNK/HATCH PIN|tied in with door | | |
TACHOMETER |*1 | | |
SPEED SENSE| gray/black | |cruise control module *4
BRAKE WIRE| green |+ | at brake switch
HORN TRIGGER| dk. blue |- | steering column
LF WINDOW UP/DN| wht/blk - orn/wht |A | at drivers door motor
RF WINDOW UP/DN|tan/blu - wht/yel |A |drivers door switch
LR WINDOW UP/DN|yel/blu - gry/orn |A |drivers door switch
RR WINDOW UP/DN|red/blk - yel/blk |A |drivers door switch
Notes:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
NOTE: This vehicle is equipted with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start. *1 Tach wire: On the 4.6L go to any of the 8 ignition coils and use the wire that is not red/green. On the 5.4L it is a lt. green/white at the coil on the passenger side of the motor between the fuel injectors. *2 The keyless module is located high in the drivers kick against the firewall. *3 One of two. The wire is in pin 11 and it is next to the black/pink wire. Test with a digital multi-meter ONLY, to keep from damaging the circuit tied into the other lt. blue/white. *4 The cruise control module is on the driver side fender. *5 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1093.
The pats box is on the driver side not exactly sure probably in the kick panel.
Hope this helps!
Marc
<o> </o>
<o> </o>
Old 01-24-2007, 07:31 AM
EagleDakota EagleDakota is offline
EagleDakota is starting off with a positive reputation.
Mdelano (Marc), Thanks for the great reply. Wealth of info! I'm printing this one and adding it to my manual. Thanks for asking the question, Eagerinsight.
Keys Ed Woods 2009 - 2014 F150 2 01-02-2017 07:23 PM
PATS Mustangguy302 Expedition & Navigator 7 11-26-2014 01:16 PM
Need some help installing a Fortin PATS Bypass... couple questions 1998F150XLT 1997 - 2003 F150 4 04-12-2013 01:00 PM
PATS bypass programming for remote start Johnnyboy04 2004 - 2008 F150 4 12-05-2005 02:06 PM
PATS Bypass Options for Remote Start GSPope Expedition & Navigator 2 01-17-2005 09:35 PM
Tags
1997, 1999, 2002, 2006, 2007, f150, ford, lincoln, located, location, module, pats, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
