1940 Ford frame - Ford Truck Enthusiasts Forums
1940 Ford frame
Old 03-13-2002, 08:54 PM
DightonFord DightonFord is offline
DightonFord is starting off with a positive reputation.
1940 Ford frame
Old 08-09-2002, 03:17 PM
Hi_Tech_ Red_neck Hi_Tech_ Red_neck is offline
Hi_Tech_ Red_neck is starting off with a positive reputation.
1940 Ford frame
Here is my question...
Someone gave me a 1940 Ford frame, I think he said it was from a 4 door or a coupe. My question is, can I get a truck on that frame. I thought they were all the same frame, but someone told me they wern't. I was also wondering where I could find a cab, and all the other little parts to make it go.. one more thing, about the transmision, what can it bolt up to?
thanks for any help
Sean
Old 08-11-2002, 10:47 PM
Carlene's Avatar
Carlene Carlene is offline
Admom
Carlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputation
1940 Ford frame
Sean - since no one else has responded yet, maybe I can help you out a little.
As for the frame, I don't know if a truck will fit on a car frame, but I do have a diagram of a frame in my gallery (just click the little picture of my truck on the left). Ours is an original 1941 truck (F100) frame which is the same as a 1940 so you should be able to measure your's to see if the measurements match up.
As for the individual parts, I think you would be better off searching for a whole truck rather than to try and put one together piece-by-piece. The original parts are hard to find and the aftermarket parts aren't that cheap.
As for the tranny, if you're using a modern engine, use a modern tranny - same with the rear, axle, etc.
Carlene
Old 08-12-2002, 12:20 AM
1940 Ford frame
Thanks for the help.... It seems to match right up, I think things will work out just right.. Did you guys have to do alot of fab work for the front and rear? Is their much to it? I am looking at getting the frame built, and not worry to much about anything else right now.. I was going to build a tank for it, but wasn't sure of what I have to work with ( clearance for the bed of the truck ) My goal is to have it done by the time I get married ( not real soon )
Thanks again
Sean
Old 08-12-2002, 03:13 AM
staffordra staffordra is offline
staffordra is starting off with a positive reputation.
Post 1940 Ford frame
horseheavenbob
The passenger frame will work for a 1/2-ton pickup, the only difference being the body brackets that are riveted on. These frames are the same from 1935 to 1940. I have a '35, '36 and '37 pickup, and with these all you have to do to use a passenger frame under a pickup is delete the outrigger ***. body brackets -- the naked frame is correct for the pickups. I'm fairly certain it's the same situation on the '40 (I used to own a '40 sedan delivery).
Hope that helps.
Old 08-27-2002, 12:57 PM
norsman1custom norsman1custom is offline
norsman1custom is starting off with a positive reputation.
1940 Ford frame
hi hi teck i got evry thing u need i got the hole truck im parting out soo give me a call 602 692 1674
Old 08-28-2002, 10:21 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
1940 Ford frame
Hi tech ,i own 2 coupes all street rods.
I built these from the ground up all ford drive train.
a few pointers on forty frames,watch out for frame twist,and cracks and rust through at the point the frame kicks up before the rearaxle
Rich
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Exhaust (cat) 1987 - 1996 F150 & Larger F-Series Trucks 7 08-23-2012 12:39 AM
Tags
1940, buy, car, chassis, diagram, explore, ford, frame, frames, kick, original, rear, s10, truck, ups
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
