fan control
Your blower motor resistor is bad.
Most of the threads that I have read on this resistor say that it is under the dash on the passenger side. You have to get way down under there and look up to find it. On the other hand, my 2002 F-150 Wiring Diagrams Manual says that on my truck this part is located behind rear seats.
A 19 axle code is 3.55 open.
Fan Speed Control Resistor
I am very glad I found this thread....Yes it was directly beneath the passenger's feet in the bottom of the duct. Two screws w/ 8 mm heads & was indeed easy to access once you knew it was there. We now have all the fan speeds back working as it should.
Thanks again to those that contributed to this thread even it was back in 2007.
Thanks, hugger94
Thanks, hugger94
Olafs 7.3 ex
03-24-2018 10:30 AM
Don Expedition
07-06-2017 03:30 AM
trk pny
01-01-2017 05:45 PM
Lukes66
05-08-2016 05:06 AM
