1982 F-150 need ignition switch picture-wire placement-on column - Ford Truck Enthusiasts Forums
Old 01-17-2007, 08:12 PM
cantedvalveFord cantedvalveFord is offline
cantedvalveFord is starting off with a positive reputation.
NEED HELP- CAN ANYONE TAKE A PICTURE OF THEIR STARTER SWITCH WITH PLUG IN IT, AND POST IT OR EMAIL IT TO ME- SO I CAN KNOW WHERE THIS WIRE SHOULD GO- THERE ARE 3 OR 4 EMPTY SLOTS WHERE IT CAN GO- READ ON:
1982 FORD F-150 4X4
I bought this F-150 a few years ago, and have been slowly de-bugging it from the previous owners f-ups. This is the one where he failed to put in all the bolts of a suspension lift kit- and it was shaking like he-ll for 2 years off and on.
Well this problem is- the truck never had a set of keys to start it- he had it rigged so you turn the key switch to run position, then push a button under the dash. hey, no big problem- nobody will ever steal the truck that's for sure
so one day last fall I decide to drop the starter switch and take a look- but when I remove the plug from it up above the steering column, a wire falls out of the plug !
ok, he's been in here too- he obviously was pulling wires from the plug, and putting them back in, and had one of those little lock tangs flattened out- so the wire fell out
only I didn't see where it was to begin with- so I picked a slot in the plug that looked right, and plugged it in- the truck starts and runs with the button as usual, but the 4WD dash light would stay on after the truck was shut off- so I would not want to park it in 4WD, I'd put it in 2WD
well it sat for a few weeks and the battery got sluggish next startup, needed a boost- but then was ok
now the battery went DEAD- I had to replace it
checked the draw at the cables- the truck now has a drain on the battery at all times- that wire I plugged back in, is in the wrong slot
or is there a picture online somewhere ?
I'd don't want to go to the junkyard, just to see a starter switch. My switch works fine, just needs to be wired correctly. The previous owner of this truck was the biggest STRIPPED BOLT MECHANIC the world has ever seen.
Old 01-17-2007, 10:32 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Starter switch ?
Ignition switch wiring or steering column wiring?
Do you mean like this connector on the column like a 79 ?
or Like this?
Old 01-17-2007, 10:39 PM
Old 01-18-2007, 06:55 PM
ok, that curved plug in looks like a neutral safety switch plug
that round plug is not it
the switch and plug I'm talking about, has a block shaped rectangular plug with plastic snap locks on it
this one is on the column, underneath the dash- it is actually bolted to the top of the steering column- and to see it, you have to put your head down by the gas pedal and look up with a light
I was hoping maybe someone had a column out with the switch on it already
I know this is asking a lot..
I'll get in there tomorrow when it's light outside and take a few pics and post them, if I can
Old 01-18-2007, 07:00 PM
Quote:
Originally Posted by Mil1ion
Starter switch ?
IGNITION SWITCH WIRING/PLUG ON TOP OF COLUMN, RECTANGULAR IN SHAPE, BLACK, PLUGS IN FROM THE TOP
NO, THIS ONE IS NOT CURVED OR GRAY
or Like this?
NO, NOT THAT ROUND TYPE EITHER
I'LL TRY TO GET SOME PICTURES TOMORROW AND POST THEM
Old 01-19-2007, 10:49 AM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
What colors of the wire you are having problems with?
If you tell me what color wire you are having trouble with, I may be able to help.
Old 01-19-2007, 11:45 AM
at this point I realize previous owner was in there unplugging wires from ignition switch plug- and moving them around
I need a picture or description of ALL the wires plugged in there- so I can return it to stock config
pics to follow
the truck never started with the key- now I know why- he f'd it up
Old 01-19-2007, 01:44 PM
Well I can tell you what the color wires to the switch are.
And I can tell you how the switch energizes the wires.
1: Circut #37 Yellow Wire: Power In.
2: Circut #687 Green/Yellow Wire. Hot in run only. Goes to fuse panel F-14 and F-15
3: Circut #16 Red/Lt Green and Circut #252 Brown/Pink wire combined to one connection, hot in start only. Goes to Ignition coil.
4: Circut #16 Red/Lt Green and Circut #20 White LB Hash wire combined in one conection hot in run only.
5: Circut #32 Red/Lt Blue wire, hot in start only. Goes to neutral saftey switch, and starter solenoid.
6: Circut #237 Black/Lt Green Hash wire Hot In run and Accessory.
7: Circut #977 Purple/White wire Hot in start goes to brake warning lamp.
What you can do with the following information, is find out which connections at the ignition switch is hot in run, start, or accessory by using a lighted tester or a multimeter. I bet most of the wires are correct.
What it sounds like to me is that the truck has a bad neutral start saftey switch and the PO instead of fixing it right bypassed the NSS using a start button and some rewiring to the starter solenoid. This is my guess with the avaliable information. But it is only a guess if you understand. Be prepared when the truck is wired at the ignition switch right, that the truck wont start. My guess.
Hope this at least helps a little.
Old 01-19-2007, 05:31 PM
The curved connector shown above is considered the column wiring in a 70's truck.
I couldn't remember which year the key was moved to the steering column.
But this illustration is what I thought you would have.
In Post #3 I linked to a schematic for your ignition switch.
Did you not look at it ?
You didn't comment on that link
Old 01-23-2007, 01:09 PM
schematics won't help- the wires were pulled from the plug itself- so I need a picture of a plug with wires in it, in original form, to use as a pattern to check this one- and put it back to stock config
yes, most likely
a. the neutral safety switch was out of adjustment, or defective
or
b. the starter switch had to be adjusted- some slide up/down on the column to adjust those as well
and the DUMB *** started pulling wires from the plug, and crimping the locks tabs flat
pics to follow today- I'm going out there NOW to take pictures
Old 01-23-2007, 01:21 PM
ok, I have the pics, how do I upload them ?
or can I email them to someone, who can upload them ?
Old 01-23-2007, 01:23 PM
thanks, but I don't need to know what each wire actually does- what I DO need to know is, WHERE in the plug each wire snaps in- because the wires were removed from the plug
Old 01-23-2007, 02:21 PM
There should be Pin numbers and letters located either on the plug or switch itself.
Could you confirm which ones you have please?
The ignition switch or connector will have either these marks at the respectable pins...
BATT: 2 of these for the Yellow Wire Battery input
I1: Hot in run. Red/Lt Green wire
I2: Hot In Start. Brown/Pink
A1: Hot in Run and ACC: Black/Lt Green
A2: Hot In Run: Grey/Yellow
5T: Hot In Start: Red/Lt Blue
P1: Hot In Start: Purple/White Ga
P2: Not used for diesel only
or they will be just numbers:
1: Hot in start: Purple/White
2: Hot In Start: Red/Lt Green and Brown/Pink
3: Hot in run and acc: Black/Lt Green
4: Hot In Run: White/Blue Red/Lt Green
5: hot in start: Red/Lt Blue 2 wires
6: Hot In Run: Grey/Yellow
7: Battery input: Yellow wire
8: Battery Input: Yellow wire
Ths is as far as my schematics go I'm afraid.
Old 01-23-2007, 05:16 PM
http://i10.tinypic.com/2rzwbo4.jpg
http://i18.tinypic.com/2mwt1c1.jpg
ok, I uploaded pics to tinypic, you can click on the first 2 links above to view them, in case this post does not display the pictures
I will look at the plug and switch, and see if the pins are labelled
the pics show the switch on top of the column, looking up at it from the floor, with plug still plugged in
then the plug itself after unplugging it from the switch
the first time I pulled this down, there was a wire that PULLED OUT of the large plug- I put it back in the closest slot it appeared to be near- obviously that was NOT the right slot, because then it eventually drained and killed my battery- and there is an amp drain on the battery whenever the plug it put in now, tested it with my ammeter
the previous owner had been pulling wires out of the plug, and putting them back in, and now I'm wondering if more of them are in the wrong spots as well
if someone could just pull this plug down and post a pic of it, or someone has a column or wiring harness for parts and post the pic, I can use it as a pattern to wire this plug
Old 01-23-2007, 06:27 PM
Quote:
It's not as easy as that because each year is wired slightly different. According to the diagrams.
1980 is different than 1981
1981 is different than 1982
1982 is different than 1983
1983 is different than 1984-1986.
You will need someone with a 1982 that is willing to take their truck apart enough to photo that connector. Most people are not going to be willing to take their own trucks apart when they are in good working order just to take a photo of a component.
Hopefully the pin numbers are printed on the connector or switch. Then it's just simply match the wires to the pin numbers.
Turn signal switch re-assemble help rews2 1967 - 1972 F-100 & Larger F-Series Trucks 8 03-09-2016 12:12 PM
Engine Light On -Dealer says Need mew Wiring Harness ? What ? cowboylmd 1999 - 2003 7.3L Power Stroke Diesel 24 03-07-2016 06:37 PM
starter switch & starter solenoid chappys4life 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 06-29-2012 12:05 AM
HELP .... Need Ignition Switch Connector Diagram sgtnike 1999 to 2016 Super Duty 0 02-18-2012 03:10 PM
Which fuse slot for hardwiring a radar detector? BMWBig6 2009 - 2014 F150 3 01-13-2012 04:48 AM
Tags
150, 1982, 1984, battery, color, diagram, ford, ignition, key, picture, placment, switch, truck, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
