What Tires Do You Run? - Ford Truck Enthusiasts Forums
Delaware Chapter Join Chapter, Leader: fire240
Old 01-17-2007, 05:07 PM
savage2211's Avatar
savage2211 savage2211 is offline
savage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant futuresavage2211 has a brilliant future
Talking What Tires Do You Run?
Well,its time for tires on my truck.I have 35/13.50/16 Pro comp A/Ts but they were not very good on wet roads.What tires do you guys run and how are they working for you.I would like to go one size bigger maybe 325/80/16. I don't go in the mud,just sand and towing my 37 Foot 5thwheel camper. Thanks guys
Old 01-17-2007, 06:32 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i used to run 35-12.5-16.5 BFG all terrain radials on my 88, and they were very good on and off road. they were quiet and wore like iron also. i put 55,000 miles on them before we put them on my partners truck. he put another 30,000 on them before they started to blow out due to sidewall dry rot after 14 years.
Old 01-17-2007, 06:50 PM
savage2211's Avatar
wow over 80,000 miles,Sounds like a great tire..what do you have on the 88 now tom?Thanks
Old 01-17-2007, 07:08 PM
i ain't rite
BFG mud terrain radials. 36-12.5-16.5
the truck is no longer a road runner, and has been relegated to workhorse duty's now. mostly towing the car hauler under 50 miles, beach running for surf fishing, and snow plowing.
it is great in the sand and snow, but it stinks on wet roads. not enough rubber on the road for the power of the engine. when you kick it on wet roads, it just sits there and spins the tires.
Old 01-17-2007, 07:12 PM
savage2211's Avatar
Thats what my pro comp tires do..I like the look of the mud terrains,but if they act the same way I guess I better keep looking..Thanks again.
Old 01-17-2007, 10:02 PM
Ronin007's Avatar
Ronin007 Ronin007 is offline
Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.
savage2211 - from your description stay away from mud terrains and get an all terrain tire. Besides the BFG AT take a look at the Bridgestone Revos. A lot of SD guys seem to like them and they are rated well on Tire Rack. Make sure you get the right load rated tire for your truck too.
Old 01-17-2007, 11:37 PM
soondg's Avatar
soondg soondg is offline
soondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud of
I had 35-12.5-16.5 BFG All terrains on my old 89 250 Diesel, they wore like iron. Had Mud terrains before that but wore the tread off in chunks and still drove back to Philly from Connecticut with the steel belts showing and 6000 lbs in the bed. That's why I bought the A/Ts the next day. I put 60,000 miles on them and they still looked new.
I have 39-15.5-15 Swampers on my truck now that I have no idea how old they are.
Just picked up a set of 38-15-16.5 Swamper TSL Radials (used) with 17/32 of tread left. Dont really know how they will handle daily driving, I may put some siping on the tread for better street performance.
Old 01-18-2007, 04:44 AM
savage2211's Avatar
I like the look of the BFG mud terrains but will they last like the A/T. How do they do on wet roads? Thanks you all of your input guys...
Old 01-18-2007, 04:48 AM
soondg's Avatar
The A/Ts where much better for everyday driving, weren't bad in wet weather. I put a lot of miles on when estimating jobs in all kinds of weather and they gave me good service.
Old 01-18-2007, 12:33 PM
Ronin007's Avatar
If you are going to get a mud terrain tire like the BFG, have it siped. It will make a world of difference. As Joe said though, an all terrain like the BFG is the better way to go. Some other options for you besides the BFG and Revos would be look at Toyo and Nitto tires. I actually like them better than the BFG's even though the BFG's have been my standby tires for years.
Old 01-18-2007, 01:14 PM
Pendor's Avatar
Pendor Pendor is offline
Pendor is starting off with a positive reputation.
Quote:
I agree.
I had these on my Bronco till I switched to a Mud Tire. I was quite happy with them. I still have 2 in my basement for emergencies that have over 40k and still passable tread.
Old 01-18-2007, 06:17 PM
savage2211's Avatar
Ok guys .I will check them out.Any other suggestions?
Old 01-23-2007, 02:16 AM
Mark _G's Avatar
Mark _G Mark _G is offline
Mark _G is gaining momentum as a positive member of FTE.Mark _G is gaining momentum as a positive member of FTE.
I have the stock Continentals on my F350, which aren't the greatest as I'm sure you know. On my '87 F150 I put on a set of Kumho MT 31x11.5x15s and they worked very well in the snow.
I see they have a newer tire with a different tread on them now too.
I bought them over the other tires because they were a lot less expensive than the BF Goodrich at the time and they rated really well on www.tirerack.com survey. I see their prices have risen considerably since I bought them approx. six years ago.
Mark
Old 01-23-2007, 03:12 AM
Mark _G's Avatar
Do any of you run 35's on a stock truck - no lift?
Just wondering because I've seen people say they did.
Thanks,
Mark
Old 01-23-2007, 04:41 AM
savage2211's Avatar
Thanks garrity,Nice looking tires,I will check them out....
Go Back   Ford Truck Enthusiasts Forums > >
Tags
15, 30, 35135016, 3815165, 95, bronco, f250, put, tires, toyo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
