Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 12-09-2002, 02:12 PM
fbushby fbushby is offline
fbushby is starting off with a positive reputation.
1940 Flathead stuck
I dissasembled the flathead V-8 that came with my 1940 pickup project.
Somebody left the carb off of the manifold letting rust grow in two cylinders that had the intake valves open. The funny thing is those two pistons weren't frozen. The no.3 cylinder is frozen with both valves closed. There is a fine layer of corrosion on the cylinder wall both above and below the stuck piston.
Do any mechanics out there know if that means the block is cracked? Could that condition happen without the block being cracked?
  #2 (permalink)
Old 12-11-2002, 07:49 PM
mtflat mtflat is offline
mtflat is gaining momentum as a positive member of FTE. mtflat is gaining momentum as a positive member of FTE.
1940 Flathead stuck
>pickup project.
>stuck piston.
>cracked?
It could be a number of things. Usually when one cylinder is different, that is the place to look for trouble. You'll just have to do some investigating while you take it apart. Look for signs of antifreeze in the crankcase - you'll see a 'high water mark' on the crank lobes if it was leaking. Check to see if your pan rails are ok.
Also look for signs of a blown head gasket over the #3 cylinder. If it was dumping coolant into the cylinder while it was running that cylinder will be cleaner (carbon deposits) than the others.
Clean out the rust and look closely at the top of the cylinder wall where the intake or exhaust valves are. What you're looking for is a fine hair-like line. Cracks close pretty tight when the block cools. With rust above and below the piston, it's possible the crack extends down the side of the cylinder wall. Good luck, and give us a play by play of what you find.
  #3 (permalink)
Old 12-20-2002, 10:48 PM
Huntsman's Avatar
Huntsman Huntsman is offline
Huntsman is starting off with a positive reputation.
1940 Flathead stuck
__________________
Tom
55 F-100 w/efi & twin-i-beams
Tags
flathead , piston , stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
