Dar
Dar
I have a 2005 F-250 6.0 Diesel with 53 K miles and the big Banks system. I am replacing the head gaskets and will ring the heads and use ARP studs. I heard of an EGR block kit that cuts out the EGR system. It is claimed it will make the ET drop by about 200 degrees. All this sounds good. However, (1) has anyone done this? (2) Will it pass smog tests? I live in Phoenix AZ. (3) are there any other things I should know about this? /><O></O>
I pull a 30ft travel trailer. Thanks!<O></O>
Hello and Welcome to Ford Truck Enthusiasts!
You will need to ask your question in the tech forums since this one is only used for introductions. Click on the forums tab at the upper left and browse over the forums, there are several that will appeal to you. I suggest this one: https://www.ford-trucks.com/forums/forum107/
Good luck and enjoy the site1
