Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Lightning belt change?
Old 01-17-2007, 10:48 AM
kpmurfy15's Avatar
kpmurfy15
kpmurfy15 is offline
I have a 200 Lightning and I need to change the belt on in. The supercharger belt was easy i just cant figure out the regular belt. How to you take off the crank pulley for the supercharger and the braket behind it. I need help fast!! I have an embarrasing squeak that needs to go ASAP...thanks
Old 01-18-2007, 10:02 PM
huitt24's Avatar
huitt24
huitt24 is offline
the bracket is held on by 1 bolt and 2 nuts, remove them and then get a 14mm hex socket and spin the pully off the harmonic balancer. Installation is the reverse but make sure you put some antisieze on the threads before you re-install it.
Old 01-19-2007, 08:00 AM
kpmurfy15's Avatar
kpmurfy15
Alright thank you, that thing is a little tricky, got me a little confused!
Old 01-19-2007, 02:53 PM
huitt24's Avatar
huitt24
huitt24 is offline
also I forgot to tell you that it is a left hand thread and that you may have to keep the engine from rotating because I believe it is torgued down to 100ftlbs. Good luck and glad to have helped ya.
obsidianspider
05-19-2013 05:23 PM
jhaas63
09-07-2012 11:28 AM
plugugly
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
09-20-2005 12:36 AM
performancenut
07-01-2004 02:16 PM
onelitreyamaha
06-08-2004 11:59 AM
Quick Reply: Lightning belt change?
