Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 01-17-2007, 10:48 AM
kpmurfy15 kpmurfy15 is offline
Garage is empty, add now
kpmurfy15 is starting off with a positive reputation.
Lightning belt change?
I have a 200 Lightning and I need to change the belt on in. The supercharger belt was easy i just cant figure out the regular belt. How to you take off the crank pulley for the supercharger and the braket behind it. I need help fast!! I have an embarrasing squeak that needs to go ASAP...thanks
  #2 (permalink)
Old 01-18-2007, 10:02 PM
huitt24 huitt24 is offline
huitt24 is starting off with a positive reputation.
the bracket is held on by 1 bolt and 2 nuts, remove them and then get a 14mm hex socket and spin the pully off the harmonic balancer. Installation is the reverse but make sure you put some antisieze on the threads before you re-install it.
__________________
2004 XLT Screw 5.4L 1/4 14.66 @ 95MPH
390 RWHP 446 RWTQ
Ground Force 2/4 drop, Roush IC SC
GMS COP's, Pace Setter LT's
magnaflow cats, x-pipe, DI/DO muffler
Hellwig rear sway bar, Custom Traction Bars
2005 SCAB 5.4L 3.73LS 2wd Roush 20's
magnaflow x-pipe/DI/DO muffler, true dual exhaust
  #3 (permalink)
Old 01-19-2007, 08:00 AM
Alright thank you, that thing is a little tricky, got me a little confused!
  #4 (permalink)
Old 01-19-2007, 02:53 PM
also I forgot to tell you that it is a left hand thread and that you may have to keep the engine from rotating because I believe it is torgued down to 100ftlbs. Good luck and glad to have helped ya.
__________________
390 RWHP 446 RWTQ
Tags
150, 54, belt, belts, change, ford, lightning, put, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
