1990 Ford, 5.8L 351 Engine component diagram - Ford Truck Enthusiasts Forums
Old 01-16-2007, 09:34 PM
Hometown Pride Hometown Pride is offline
Hometown Pride is starting off with a positive reputation.
Does anyone know what all those hoses and other components do? Every time I look under the hood of my F350 I cant imagine what half of these things do. Is there a place to get a diagram with an explanation to these hoses.
On another note, has anyone ever seen a trailer brake set up in the cab with a steel line running from it to the brake cylinder. If you have could you tell me what it does. Thanks
Old 01-17-2007, 06:04 PM
rat a rat a is offline
rat a is starting off with a positive reputation.
I think you can go to advance auto and they can give you a diaghram of all you vacuum hoses, they have Alldata at all the stores to help you.
and on the trailer brake control, the steel line if for actvaction of the trailer brakes, I think they are against the law in most states (unit from the 70's)
some state still allow them if your trailer is less than a certain weight like 1000 lbs.
Old 01-17-2007, 06:53 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Where did you hear this information, first I have heard of it. I have two trucks (77 & 83) set up with the steel lines for activation of the trailer brakes.
I heard that you could not use that type with ABS I never heard about it being against the law in older trucks without ABS.
Old 01-18-2007, 08:45 AM
Indiana DOT
Emission Control System '79 F-100 302 Bewildered33 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-24-2015 08:47 PM
5.4 Engine Diagram BigMike_951 Modular V8 (4.6L, 5.4L) 10 07-06-2014 07:31 PM
78 F350 Vacuum hoses McSwisher 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-16-2014 03:46 AM
Heater hoses uh60 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-28-2013 06:02 PM
Front End Diagram johnferg 1999 to 2016 Super Duty 4 06-17-2012 05:35 PM
Tags
1990, 351, 58, 58l, 58l351, breakdown, component, diagram, engine, f150, f250, ford, hose, motor, truck, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
