factory block heater question
Last night it was -17 below so I plugged my truck in at 5:00am, went to start it at 7:30am, motor spun like it was 70 degrees out. Since 2 or 3 hours seems to be enough with these factory block heaters, does anyone know if they can be left plugged in all night without any ill effects? I don't seem to have much long term success with outside timers, so I thought maybe I'll just plug it in when I go to bed and leave it until the next morning. Also does anyone know of the wattage rating on the factory block heaters (1998 F-150 4.6)? Thanks for any advice.
Spotty..
Spotty..
Your owners manual states "An engine block heater warms the engine coolant, which improves starting, warms up the engine faster and allows the heater-defroster system to respond quickly. Use of an engine block heater is strongly recommended if you live in a region where temperatures reach -23° C (-10° F) or below.
For best results, plug the heater in at least three hours before starting the vehicle. Using the heater for longer than three hours will not harm the engine, so the heater can be plugged in the night before starting the vehicle.
To prevent electrical shock, do not use your heater with ungrounded electrical systems or two-pronged (cheater) adapters."
Originally Posted by ATC Crazy
I wish my truck had a block heater....
as far as leaving it plugged in? not a problem, as people have posted. previous vehicles had them and they work GREAT! plugged 'em in b4 i went to bed, in morning, cranks right up! wahoo!
