I do not know of any direct kits but I think you can turbo anything. The exaust manafold would have to be fabricated to run the turbo. Then you would have the turbo run into the aluminum intake tube. You would probably need larger injectors and possibly get into the computer. I have heard of people turbo charging 300s but I do not know how. Have you considered supercharging? You can turn it on and off with a clutch in the gears and I understand that the gear ratios on the blower determine where in the rpm range you get boost.
