largest tires
Old 01-15-2007, 06:57 PM
scottty's Avatar
scottty
scottty is offline
largest tires
Hi i have a 991/2 F-250 4x4 cc. I was wondering what was the largest tire i could fit on the truck 35'' ?. The truck has a single leef spring lift front and rear. Thank you for the help.
Old 01-15-2007, 07:04 PM
travis dasher's Avatar
travis dasher
travis dasher is offline
I could be wrong but I dont think 35" will fit without at least a leveling kit. 33" or 305 will be the largest. On the stock 7" wide rim 12.50" width is the widest the rim will hold. Hope this helps
Old 01-15-2007, 07:08 PM
scottty's Avatar
scottty
scottty is offline
Thanks for the input. The truck dose have a 2'' add-a-leaf spring lift
Old 01-15-2007, 07:11 PM
travis dasher
The 35's should fit then. Maybe slight rub when you turn the wheel all the way to the right or left, that also depends on if you get an aggressive tread pattern. All Terrain should be fine.
Old 01-15-2007, 07:30 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Heres 305's on stock wheels at stock hieght. At right and left stop points there is just a little rub.
Old 01-15-2007, 07:39 PM
travis dasher
Talking
There you go. I stand corrected, definatly will not be the last time
Old 01-15-2007, 09:10 PM
scottty's Avatar
scottty
scottty is offline
Thanks again. Do you know the actual hight on the 305's.
Old 01-15-2007, 09:19 PM
sean23johnson's Avatar
sean23johnson
sean23johnson is offline
i know they are equal to a 33x12.50x16. they are the same height as a 285x75x16 just a little wider.
Old 01-15-2007, 09:20 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
my 305/70r16's sit about 31.5-32 inches overall height.
Old 01-15-2007, 09:21 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
33.1" on the BF Goodrich T/A's. it depends on the manufacturer to be exact
File Type: pdf
Old 01-15-2007, 09:27 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Hmm...I have those 285s on a stock suspension and no rub. Maybe I ought to measure that but they are about 50% tread now.
Old 01-15-2007, 09:30 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
I am running 295x75x16 and i get rub at before both stop points, fairly aggresive mud snow. will be dong a 2 inch leaveing kit when i ned new tires and go up to 305 then. and hope no more rub
Keith
Old 01-15-2007, 10:33 PM
PowerstrokeJunkie
Keith did you know that a 295/75 is a taller and narrower tire than a 305/70 which is shorter but wider? Its only a half inch to an inch in either direction..
Old 01-16-2007, 06:45 AM
rjrhodes's Avatar
rjrhodes
rjrhodes is offline
Keith
Also running BFG 295/75/16's on stock wheels with no rubbing issues.
Old 01-16-2007, 08:02 AM
luvemhot's Avatar
luvemhot
luvemhot is offline
Kris
I did not know that
I thought that the 305 were taller by the small amout only the other way.
thanks
Keith
Quick Reply: largest tires
