Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #31 (permalink)
Old 01-18-2007, 04:02 PM
Omahastro1 Omahastro1 is offline
Garage is empty, add now
Omahastro1 is starting off with a positive reputation.
On the question of to use or not to use a friction modifier. If you have a limited slip differential (LSD) then make sure the oil you use has the friction modifier added. I have seen it both ways, from many different brands. If it does not make sure you add it. As for spark plugs for most of us we are going to tune our trucks once in 100--150 thousand miles why mess with it. Use Motorcraft and be done with it. If they lasted as long as they have whats another $10.00.
  #32 (permalink)
Old 01-18-2007, 04:43 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
PLATINUM SPONSOR
2011 O.E.M BABY!
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
here is what Ford sent me, also they said they would see if there is any data to support using Motorcraft Plugs.
Ed
The easiest answer is that Motorcraft plugs are made to rigid OE specs. and are designed, engineered and recommended by Ford -- no other spark plug brand (including Autolite) can make that claim. I think we have good brand loyalty because many folks recognize Motorcraft is the plug the "car was born with".
I will ask our Engineers to comment on test data as I do not have any. However, I am very confident in the quality of our products given our Engineers must approve and sign off on every part.
Also, Motorcraft recently launched our new nickel alloy spark plugs that fit some new OE applications -- these plugs are lower priced than Platinum and are not offered by our competitors. Check out part #'s AGSF22N, AGSF24N, AGSF32N, AGSF34N. Good coverage at great prices.....
Last, Motorcraft prices are very competitive vs. all major competitors...
Please let me know if you have any questions......
Geoff Smith
Geoff Smith
Ford Customer Service Division
Product Manager - Maintenance Team
__________________
  #33 (permalink)
Old 07-24-2008, 02:08 AM
Izb Izb is offline
Izb is starting off with a positive reputation.
AGSF32N - bad!
I had AGSF32N on my new Ford Escape-2006 (plant used them instead of AGSF32WM1 :-( ) and had incandescence (detonation), with the rise in debt mountain. I think, too low heat range.
I bought and put AGSF32WM1-detonation disappeared completely.
  #34 (permalink)
Old 07-24-2008, 03:07 PM
turborich's Avatar
turborich turborich is offline
turborich is starting off with a positive reputation.
autolites are not the same but are considered to be the closest to motorcraft. I will always shoot for motorcraft 1st, autolite 2nd & never consider anything else in a ford. What ever you do, don't fall for those plugs with multiple tips or so called capacitors that store the spark. Why on earth would you multiple tips when the spark only jumps to one tip at a time anyways? They do not arch to all 4 at the same time!!!! They are gimmicks that people fall for!!! It's all marketing and that's it.
__________________
2000 Ford Expedition XLT
2004 Ford Explorer XLT
2000 Ford Focus SE
Tags
2003, 2005, 94, agsf32n, autolites, escape, expedition, explorer, ford, good, manufactures, motorcraft, plug, plugs, shocks, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
