49 F1
49 F1
I am restoring a 49 F1 1/2 ton 239, 4 speed. I have a bad 239 block. After 2 days in an acid tank cleaning it, it magged with a crack between the cylanders and the mechanic advises not to fix. I am trying to locate a good one. I would also like to find a good stock 3 speed floor shift. Direct gear shift the Ford manual calls it. Can anyone help me with this?
Guest
Posts: n/a
49 F1
I have 2 blocks that I will sell if your interested. I just picked up a block out of a warm basement after 25-30 years storage. Needs degreasing and magnufluxing to check if OK. The other came out of truck with 34,000 miles. needs same done to it. will sell at very reasonable price.Located in Ct. E-mail me at CLUSSY38(No Email Addresses In Posts!) if interested. Barry
Guest
Posts: n/a
49 F1
Those engines are getting harder to find. The
cracking problem you have is so common that sleeve
kits are available. Also, call Motor City
Flatheads in Dundee,Mich.(313) 529-3363 for
advise. They do COMPLETE machine shop work on
flathead Fords. There is no guarantee that any
block you buy will be an improvement.
bluesalomon
Ford Truck Parts for Sale
05-04-2016 07:16 PM
3rdshiftDiscretion
16
06-18-2011 05:08 PM
