Fuel shut off solenoid - Ford Truck Enthusiasts Forums
Old 01-15-2007, 05:13 PM
Jakeman68 Jakeman68 is offline
Jakeman68 is starting off with a positive reputation.
Hello all. My friend has a 1994 Ford 7.3 IDI diesel with a Hypermax turbo setup on it. It keeps blowing the 20amp glow plug circuit fuse. Now I traced the wiring to the fuel shut off solenoid on the injection pump (connector on the drivers front side of pump). Unplug it and the glow plugs now cycle and I have a wait to start light again. I haven't tried starting it because the batteries were dead but am now charging them. My question is I have talked to the Ford dealer and found that this part is only serviced as a injection pump itself. I then talked to the International dealer and he said he "thinks he did just the solenoid once" but couldn't give me a price or part #. I am sure someone has come across this before. I am new to these older diesels so any help would be greatly welcome. Thanks ahead of time.
Old 01-15-2007, 05:29 PM
Hamberger Hamberger is offline
Hamberger is starting off with a positive reputation.
You will need to find a local injection pump shop that handles Stanadyne pumps.
There are two solenoid under the injection pump cover, one is the fuel shut-off (larger one) and one is the timing advance (smaller one)
Be careful if you are going to do the replacement yourself. If you don't do the job right you could trigger a run-away where the truck can not be shut down. Not a pretty sight watching your engine blow itself to pieces and there is next to nothing you can do (other than maybe cut the main fuel line)
It might be best to let the injection shop handle the job.
What most likely happened to your old solenoid is that somebody left the key on without the truck running. The fuel shut-off solenoid need fuel flow across it for cooling. If the key is left on without the engine running for too long the solenoids overheats, cracks and burns out.
I recently tried to get the Injection pump in my 91 F350 rebuilt and one of the many reasons why I opted for a replacement pump was that my fuel shutoff solenoid was cracked and needed replacing as it probably would not have lasted much longer.
Seb......
Old 01-15-2007, 10:29 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
They sell them here........
http://www.mwfi.com/dieselPage/ford_73.htm#solenoids
If you want the TSB for removing the governor cover on the IP send me an email, click on my name ........please use subject IP TSB.
Old 04-22-2009, 04:52 PM
lunatech's Avatar
lunatech lunatech is offline
lunatech is gaining momentum as a positive member of FTE.
Just had the same thing happen to mine. If you could, please send me the IP TSB. I tried to click on you name but it will not let me send you anything. E-mail is LunaTech1@netzero.com. Thanks.
Jeff
Old 04-22-2009, 08:42 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
Ok are you sure it is the fuel solonoid wire or the cold advance wire If it is the cold advance just leave it unhooked it will run fine some guys say they even start better, I have tried it and found no difference.
Old 04-22-2009, 09:17 PM
lunatech's Avatar
Yep, I'm 100% sure it's the fuel shutoff solenoid. Thanks for stop and making me think though.
Need Help Wont Start MrsCopenhagen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 12-09-2013 06:25 PM
Truck won't shut off 96ford250 1994.5 - 1997 7.3L Power Stroke Diesel 27 11-01-2013 03:19 PM
6.9: No Fuel at Injector. Is there an electrical shutoff? kpwall Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 05-12-2012 10:36 PM
diesel glow plugs not working 1988 light truck Ken Claydon 1987 - 1996 F150 & Larger F-Series Trucks 3 07-01-2011 10:23 AM
7.3idi Cold Idle Circut vfelix702 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 01-11-2011 09:00 PM
Tags
2001, 350, 73, 73l, 92, advance, cold, cut, diesel, f350, ford, fuel, injector, international, pump, shut, shuts, solenoid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
