Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
View Poll Results: Spark plug blowout, has it happened to you?
Yes, on 5.4 engine. 42 26.25%
Yes, on 4.6 engine. 8 5.00%
Yes, on 6.8 V-10 engine. 2 1.25%
Never happened, knock on wood . 108 67.50%
Voters: 160. You may not vote on this poll
  #31 (permalink)
Old 12-05-2008, 11:23 PM
Zookie400's Avatar
Zookie400 Zookie400 is offline
Zookie400 is gaining momentum as a positive member of FTE.
head gasket? no way was that harmed from a blown spark plug.
  #32 (permalink)
Old 12-14-2008, 10:29 AM
BlackBetty05's Avatar
BlackBetty05 BlackBetty05 is offline
BlackBetty05 is starting off with a positive reputation.
Quote:
Originally Posted by JCA433 View Post
Is this a big problem for the 2005 F-150 trucks? I have read about this problem on the internet and it seems quite common.
I was wondering about this also ^^^
I hear it is. Anybody else?
  #33 (permalink)
Old 12-14-2008, 03:48 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
All 3-valve engines have a different plug configuration. It's harder to get them OUT then keeping them IN
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #34 (permalink)
Old 12-14-2008, 07:44 PM
fairchase fairchase is offline
fairchase is starting off with a positive reputation.
Is there any kind of preventative maintance one can do to hopefully kepp this from happening?
Kinda wondering about my decission to buy the 2001 F 250 5.4 now?
  #35 (permalink)
Old 12-15-2008, 06:55 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Proper torque and anti-sieze on the plugs and you should be fine. It is a small percentage that actually fail. Our 2000 5.4L in a F250SD where I used to work had over 115,000 miles on the original plugs with no problems.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #36 (permalink)
Old 12-16-2008, 05:32 PM
hangman hangman is offline
hangman is starting off with a positive reputation.
yeah , finally happened , 3rd one back , pass side.left it in garage 3 days , while my blood boiled, used kd kit , took all of 45 minutes to fix included r&r fuel rail...as far as steel insert in aluminum head, i'm origanally from south shore of L.I. and used the KD inserts on outboards (probably 500 or so), and never once had a problem....anybody swap out a 3 valve into an earlyer 2 valve truck, can't find any info on site.. love my 01 SD, and would rather cange to later motor .4 thread plug holes scare me a little.
  #37 (permalink)
Old 12-16-2008, 05:55 PM
Krewat's Avatar
hangman, I too live on the South Shore
You can go to the later heads, 2003 model year or so, through 2004, that have 7-8 threads for the plugs. Either that, or do inserts on all the plug holes.
__________________
  #38 (permalink)
Old 12-20-2008, 07:58 PM
Selder Selder is online now
Selder is starting off with a positive reputation.
Well you can add me to the list now. I just lost my first plug on the 5.4L in my 98 Expedition. It has 139k on the clock and it is the fisrt plug I've failed since i've owned it (~50k miles).
I was hesitant but I bought the Timesert kit (p/n 5553) from Fastenal for $331 out the door. I initially was ticked that it cost that much but after getting and using the kit I can say that it is very well designed. It took me about 1 hr to get to the offending hole and get the insert installed. I cannot comment on the durability yet but the directions were very clear and complete and went exactly as described. I recommend this to anyone who has access to an air compressor and air ratchet.
Steve
  #39 (permalink)
Old 12-25-2008, 12:03 AM
dadlovesfords's Avatar
dadlovesfords dadlovesfords is offline
dadlovesfords is starting off with a positive reputation.
#6 on the wife's 2002 Expo. Used the Calvan 38900 kit. All went well no hassles. But I wouldn't want to try the job without air and a good air ratchet! Also did 2 for my buddy that has a shop. 1 2001 SCrew #6 , and 1 1998 SCab #3. All were the 5.4 engines.
  #40 (permalink)
Old 12-30-2008, 09:17 AM
RAMRODMUDDER RAMRODMUDDER is offline
RAMRODMUDDER is starting off with a positive reputation.
5.4l 3v Spark Plug Blowout
I had my #4 plug blow out, Come to find out that the injector was stuck open. When the dealer put a new plug and injector in the connecting rod broke and jammed up against the block so ford is replacing the short block, i thought i was going to have to pay for a new head cuz they thought the threads ripped out!!! i am going to trade my truck in so i don't have to deal with Ford's dumb design with the sparkplugs and injectors. i'm better off with my Dodge!!!
  #41 (permalink)
Old 12-31-2008, 12:00 PM
Krewat's Avatar
Again, I must remind everyone who has NOT had a problem to VOTE in this poll to keep things somewhat realistic.
RAMRODMUDDER, stuff happens. Was it covered under warranty? Or are you paying out of pocket?
As for the "plug blew out, injector was stuck open", one doesn't happen because of the other. Sounds more like the shop screwed up the insert install and blamed it on an injector. BS alarm is ringing...
__________________
  #42 (permalink)
Old 12-31-2008, 01:16 PM
pony pony is offline
pony is starting off with a positive reputation.
I'd really like to reply but it won't let me...."this post is closed" is printed at the bottom of the results. Has been that way for some time.
  #43 (permalink)
Old 12-31-2008, 01:29 PM
Stone Mathews's Avatar
Stone Mathews Stone Mathews is offline
Stone Mathews is starting off with a positive reputation.
Yeah Art, I'm seeing the same thing.
I'd like to vote but it tells me the poll is closed.
Thanks!
Stone
__________________
1999 F-250 SD, SC, XLT, AT, 5.4L, 4.10 gears, 4X4 (8/98 Build)
285/75/16 BFG T/A KO
1985 Ranger 350V, 1985 Johnson GT150
  #44 (permalink)
Old 12-31-2008, 01:41 PM
Krewat's Avatar
Oh, and I went to edit the thread, and I can't - not a mod of this forum - forgot were in the modular V8 forum.
Oh well...
__________________
  #45 (permalink)
Old 01-01-2009, 11:14 AM
Krewat, i know stuff happens. Ford is Going to fix it cuz the injector caused everything and The 3V 5.4L head i got Do Not Have Any Inserts. How ever this happened i dont care it's getting fixed by ford and it sucks cuz i love the truck just hate the motor, oh well stuff happens
Tags
02 , 150 , 2003 , 38900 , 54 , blow , calvan , crew , engine , f150 , gt , miles , mustang , plug , plugs , replacement , spark , timesert
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
