57-60 F100
welcome, 57f100!
i am new around here too, also a 57-60 lover. i have a 60 long fleet with MII front. It has always been my understanding that the front leafs/i-beams and rear leafs/diff were different when comparing the 53-56 and 57-60 f series. it would not surprise me if the rails were dimensionally the same, especially in back given the step side usage from 53-72(79?)
i am currently selling/parting a '58 short step with quite a bit of good stuff and an uncut dash. if you or anyone else need anything, let me know. i am in central california.
bigredtodd
bigredtodd
1957-1960 F100 4x2 Frame 110" w/b
1957-1960 F100 4X2 110" Wheelbase
____________________________
C0TT-5006-FB .. Frame Assembly
C3TZ-5019-E .. Front Crossmember
B7C-5026-A .. #2 Crossmember
B9TB-5030-B .. #3 Crossmember
B9TZ-5037-A .. #4 Crossmember
B9TZ-5035-A .. Rear Crossmember
By the part numbers, the 1957-1960 Frames are different from 1956.
Received 1,353 Likes
on
on
Originally Posted by BIGREDTODD
welcome, 57f100!
bigredtodd
bigredtodd
Just so you know, that FoMoCo's proper designation for our trucks is "Styleside" & "Flareside", not Brand X's "Fleetside" & "Stepside".
Col. does that mean that the "frame rails" are the same as in they will interchange or what does it mean. It seems that a lot of 57 - 60 guys have looked for the cab mounts and had no luck in finding them. Does that mean that the 56 ones will work on the 57 - 60? How about the bed mounts? Are they the same? Are all the crossmembers the same. It would seem if they are, then us 57 - 60 guys could by a new 56 repo frame to replace our damaged ones. Is this true Col.?
Col,
Regarding post #19 you are totally correct. Most of my fellow gear heads are fans of leaky timing covers and redneck wiring jobs (i.e. chevy and dodge). I am used to dumbing down the terminology for them.
Still not used to conversing in "blue oval-ese" yet.
You have provided a lot of good info above.
bigredtodd
bigredtodd
These guys carry cab mounts for our trucks. Haven't tried them out yet, but they're listed. http://www.classicfabrication.com/
on
60RatRod
55
08-02-2021 01:47 PM
Dano78
03-28-2013 07:53 PM
Schuyles
11-06-2012 10:19 PM
kooper909
16
08-14-2007 04:00 AM
truckfarmer
04-22-2005 04:45 AM
