Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-14-2007, 08:41 AM
newr newr is offline
Garage is empty, add now
newr is starting off with a positive reputation.
Flash Point Question
Greetings
I just read an article that listed the relative flash point tempratures of conventional gasoline, 40deg.F, #2 diesel, 125deg.F, and bio-diesel at nearly 300 deg F.
This created more qustions for me so I thought I would throw them out to see what you all know on the subject.
Does the higher flash point create starting problems?
Has anybody gone so far as to install intank heaters and then insulate lines to the engine? A pre-heat process? If so what changes, if any, did you make to the injectors or IP?
I realise that the fuel is all bio-degradable, but with the high flash point has anybody tested exhaust gasses to know anything about efficiency?
__________________
Ron In Oregon
'99 F250, V10, Man. Trans., 4 Door Ex. Cab, 4X4
'00 Ranger 4.0, 5 Sp. 4 Door Ex.Cab, 4X4
  #2 (permalink)
Old 01-14-2007, 10:05 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
Quote:
Originally Posted by newr
Greetings
With a Diesel engin it the Autoignition temperature that lights the fuel. The stange thing about gasoilne is that it has a lower flash point than Diesel but a higher Autoignition temperature.
Petrol:
Flash point: >-45 °C (-49 °F)
Autoignition temperature: 246 °C (475 °F)
Diesel:
Flash point: >62 °C (144 °F)
Autoignition temperature: 210 °C (410 °F)
I can not find a autoignition tempweature for Biodiesel or WVO.
I forgot to switch my truck back to Diesel on shutdown when we were up on Mt. Hood playing in the snow and it started like normal on WVO @ 20 F.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
