You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm getting another converter box sent to me from JC Whitney. I'm not getting any voltage on the output on the right side, I've got good voltage going in. I'll get back when everything is in.
__________________
- Chris -
Mine - 2002 7.3L F-350 Dually, Lariat, Crew Cab,
Long Bed, 4X4, F-5 DP-Tuner and 60+ mods
Hers - 2004 6.0L Excursion, Limited, 4X4, IDP Custom SCT-X3 and a few mods
this is alot like when I use to modify my rice burner with side markers. When I did it all I did was run the leads to the front turn signals also and running them the opposite, achieving the same thing without buying the extra deal you did, by wiring to the running light they served as running side markers, and then running the other lead to the blinker they would blink opposite of the stock turn signals, they would get ground when blinkers were on and in turn blink opposite
Can you give me a little better wiring schematic? I guess I'm getting lost when you said "running them the opposite". Do you mean that after you make the initial connection of the positive wire to the brown wire for running lights, you run a wire from the turn signal positive to the mirror light negative? Just a little slow on the upkeep here i guess...
__________________ 2002 F350 Supercab, 7.3, 4wd, auto, 114k.
PHP Tuned, 05/06 Grille, 6637, Zoodad, Trans. Temp and Pyro Gauges, High Idle Mod., Fog Light Mod., LED Mirror Light Mod., Foil Delete, Walker BTM w/4" stainless tip, SS HPX
Here is the link to the little round mirrors. I tow a 31 foot fiver behind me and it is great for watching my back tires on turns and the tires on the trailer on turns..I HIGHLY recommend them...
I know this is an old thread but couldn't you just tap into the mirror wire harness to add the turn signal? I have an 04 EB that had the non-towing mirrors with the turn signal that I replaced with standard tow mirrors with no lights. I would think I would just have to ID the wire in that group and then hook up the new light and be off to the races, right? Or did I miss something?
This is such an old thread... I completely missed it when it was going on.
Hey Chris... I really like that image of you in that mirror cover, but you sure have gained weight since then, haven't you, and I never noticed before how short your legs are!
__________________ Pete (F250_) -- PAA#19 '02 F250 PSD, CC, SB, XLT, 2WD: 231K miles
Basic, low cost, not really performance enhancing mods. '03 Excursion PSD, 2WD, 165K miles - Stock. http://guzzle.rbmicro.com/7pt3/Mods.html
LOL! I seem to have that fun-house mirror thing happening in that pic don't I?! If my legs where that short in real life, I'd be a tripod!
__________________
- Chris -
I knew I would be inviting some type of "braggart" response from you on that note, but you have to admit that even a tripod with legs that short isn't much to brag about!
Sorry, Chris, but I just couldn't resist.
Now thats funny right thar, I don't care who you are.
__________________ Brandon PAA MEMBER # 7.3, 99.5 CC,4X4,SB, leveled,live tuned by Jody,1.15 van turbo w ATS housing,6.0 IC,AFE big boost filter, Petes Armour,fuel bowl delete,black MBRP stacks, 02 headlights,F650 dash, 16x10 MT wheels, 35" tires,and a bunch other stuff that wont fit in my sig. 322K and counting.
the short answer is yes, I've done it to almost all my rice rockets in the past!
Dont know if any of you are still around. I am wanting to mod my mirrors, but not this way. I want to shorten the mirrors and narrow my truck 6 inches.
So while yo uhad your mirrors apart, do you recall seeing a way to shorten the telescopic tubes?
I have not figured out how to pop the mirror lens off yet. If i can take it aprt and shorten them, and still have the ability to extend them , they would be perfect for me.
__________________ 2001 F-350 V10 Auto CC SB SRW 4x4 35's 4" Lift
This definitely like a simpler way of wiring things. Just to make sure I have some of it correct. First off, it seems like the front turn signal bulb under the headlight might be a single element bulb that burns steady with the running lights and then blinks brighter with the turn signal? I didn't notice that it was a 2 element bulb but I am not certain of this. Also I am confused about what makes them blink opposite of the truck signals? Does the JC Whitney led bulbs have 2 hot wires....one for steady lights and one for blinking lights? Any more input would be greatly appreciated as this looks like a simple mod, except for the wiring through the mirror thing...Dave
__________________
ARCA racing and FTE rules!!
6637,CCV,AIH,DP Tuner, Harpoon & Hutch, Sonnax, 6.0 Tranny cooler, EGT,TRANNY TEMP, BOOST, AIR & OIL press, WATER temp gauges, 160db Train horns & onboard air system, inside bed tiedowns, highly modified stacks, C-Betr towing mirrors,Truxedo bed cover, Foglight mod.
