What is the stock HP and TQ for a 1977 truck 302 - Ford Truck Enthusiasts Forums
Old 01-13-2007, 12:43 AM
reed1951's Avatar
reed1951 reed1951 is offline
reed1951 is gaining momentum as a positive member of FTE.
Question What is the stock HP and TQ for a 1977 truck 302
I have a 77 f100 short bed with a really good running stock 302. I can't find out how much power it has cause I just bought it and the trans was bad. Does any body have any numbers on HP and TQ?
Old 01-13-2007, 01:47 AM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Well it says here in my book (Ford F-100/F-150 1953-1996) that the 302 had 136 net hp @3600 rpm and 245 net (lb/ft) at 2000 rpm dont know which the net part means but i guess thats ball park around there
Old 01-13-2007, 02:09 AM
repou repou is offline
repou is starting off with a positive reputation.
Well a lot of it depends on what the 302 is out of and what year it is. If memory serves me 302 was not an option in a truck in 77. I could be wrong. If I am I am sure some one will chime in and let me know.
Old 01-13-2007, 02:50 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Exclamation 302
302 V8: F Series 1971
302 V8: E Series 1968 (1969 model introduced mid year 1968)
Old 01-13-2007, 12:52 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Quote:
That info is incorrect.
There were several 302's available.
The 1968 302 2v was rated at about 200 HP
The 1968 302 4v was slightly higher at about 212 HP
The 1967 289 put out 215 HP
The 1968 289 was rated at 195 HP
These were all rated at the crank.
The info on the 302 is available in the V90* Engine forum where 302 engine questions go
expect it to be around 120 HP
The 351M was 148 HP
Old 01-13-2007, 07:55 PM
cujo8's Avatar
cujo8 cujo8 is offline
cujo8 is starting off with a positive reputation.
Just for confirmation, my 1977 F150 came with a 302 V8, 2bbl carb, C4 Automatic, which was Engine Code G on the VIN.
Old 01-13-2007, 11:34 PM
reed1951's Avatar
sweet, thanks guys
How much HP/TQ do I really have? WA_PSD 1999 - 2003 7.3L Power Stroke Diesel 42 04-06-2012 01:55 PM
!!PROGRAMMERS!! KING-RANCH02 1997 - 2003 F150 3 01-10-2011 07:39 PM
302 clevor vs. 302 stroker? havi Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 09-20-2009 11:38 PM
95 F150 5.0 dyno tests? jade79 1987 - 1996 F150 & Larger F-Series Trucks 5 11-13-2006 07:17 PM
460 Horsepower partsBoy Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 11-08-2004 04:11 PM
Tags
150, 1977, 1979, 1996, 302, 77, f100, f150, ford, horsepower, horspower, hp, stock, tq, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
