OK guys i have a problem
I believe the IDM is mounted on the driver side firewall in the engine compartment. I don't know what any of these items, IPR and ICP would have to do with your bus error code or AE problem except for maybe a short somewhere is causing it. Where did you find a u1262 error code?
As for the IDM:
Injector Driver Module
The Injector Driver Module controls power to the fuel injectors based on information received from the PCM. The Injector Driver Module receives two digital control signals from the PCM: the Fuel Delivery Control Signal and the Camshaft Position signal. The Fuel Delivery Control Signal is used by the Injector Driver Module to control injection timing and injection duration. The CMP signal provides synchronization to the engine's first and the fifth injector (firing order, cylinders number one and four). The Injector Driver Module verifies that Fuel Delivery Control Signal and CMP occur at valid timing intervals for synchronization.
As for the IDM:
Here's the other two:
Injection Control Pressure Sensor
The Injection Control Pressure sensor is a variable capacitor sensor that is supplied a 5-volt reference signal by the PCM and returns a linear analog voltage signal that indicates pressure. The sensor measures the oil pressure in the LH injection rail. PCM uses this information to determine injection control pressure. The Injection Control Pressure sensor along with the Injection Control Pressure Regulator form a closed loop fuel pressure control system.
If the PCM detects an inoperative Injection Control Pressure sensor, the PCM will control injection control pressure from a PCM-estimated injection control pressure.
Injection Pressure Regulator
The Injection Pressure Regulator controls injection oil pressure. An electrical signal to a solenoid creates a magnetic field which applies a variable force on a valve servo to control pressure. The quantity of fuel delivered to the combustion chamber is proportional to injection control pressure.
An open circuit will result in minimum oil pressure and a no-start situation. A short circuit results in maximum oil pressure, and is limited by a mechanical pop-off valve to 27,580 kPa (4000 psi).
Still do not see how this will cause the AE to kill the engine but what do I know? Heck, for all we know there is a short in the wiring in the steering column that shorts out when you plug in the AE. I am maxed out on this one buddy. Hopefully a smarter fella will come along. Good luck. BTW, what mods are on your buddies truck?
I also had a hard time to get AE to connect this time,i had to do it 3 times to get it connected,but still cant run any tests.
He has no mods on the truck.Truck has 94,000 miles on it.
Thanks for your help.
edit:anyone know what a communication bus fault is?
Originally Posted by Green_Dually
IHow would i know if it the PCM?
Yeah i was thinking of that to,just didnt want to fry my PCM.Hes a good friend,the kind that would buy me a new PCM if mine blew.But i think i will take his and try it in mine.There both autos,so that no problem.
Its weird,cause when i plug in the AE its fine at frist,but when its retrieving sensors,the engine light turns on,the wait to start light also turns on,after i plug in AE.
But when i do it in my truck the light does not turn on.
Also i cant clear his PCM codes,but i cleared mine with no problem.
So thats why i suspect the PCM.
Yeah, if his is bad, I highly doubt it can hurt yours, after all, your PCM will not be in there. As for putting yours in his, that is a crap roll. If there is a short in there, it could zap yours. If it is just the PCM though, yours should run it fine though. So you gotta ask yourself, do you feel lucky? If it were to fry yours, now you are out two PCMs and still have a problem in his truck.
Thank for all the help tenn.
Yeah,i think your right.Ill take his and put in mine,ill keep mine for me lol.But if the truck wont start at least we know what it is.
Originally Posted by slc10844
Just a suggestion, you might want to check the wiring under the hood for cafed/shorted/corroded wires or loose connectors. Also check the grounds for good contact. I think there are some fuseable links under the hood also. You might get lucky and find a easy solution.
We checked most of the plugs,even the pcm connector.We didnt see anything.
The weird part is the AE is not connecting to any of the injectors,or any other sensor.
And when the truck was running,AE would shut the truck down when i pluged it in.
#29
#30
noticed you mentioned my name, lol! And yes, alot of his confusion sounds like what I was having. New pcm did it for me, but the IDM had already been replaced. I'm worried the IDM CAUSED the PCM failure, so be leary of both.
Also, do you have AE running when you plug in? you might be defaulting into a KOEO test and THAT would kill it, too
good luck!
good luck!
