PCM for FOrd F150 - Ford Truck Enthusiasts Forums
PCM for FOrd F150
Old 01-12-2007, 07:49 AM
jmg12 jmg12 is offline
jmg12 is starting off with a positive reputation.
PCM for FOrd F150
DOes anyone know how to check to see if your PCM is bad? I was driving and the truck died. I am not getting power to the fuel pump and I followed the wire back to the PCM. ANy ideas?
Jerry
Old 01-12-2007, 02:23 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Welcome to FTE jmg12.
The PCM supplies ground for the pump to operate. Power to the pump is via a 20A fuse (F10) in the Battery Junction Box (BJB). The fuse supplies power to the Fuel Pump Relay which is also in the BJB (301). The relay supplies power to the Inertia Fuel Shut Off (IFS) switch. The IFS supplies power to the fuel pump. The power wire is Pink/Black. Good luck!
Old 01-12-2007, 05:45 PM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
Hmmm, musta read that one out of AllData?? Just check the pump fuse and both wires at the IFS switch for voltage then get back to us..... You could also manually ground the pump and see if it runs. Unhook the pcm harness and use a computer safe(low resistance) test light to ground the wire from the fuel pump and see if it runs. I don't have the schematics in front of me and i don't remember how the circuit is set up...
Old 01-12-2007, 06:09 PM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
Try a new fuel pump relay first. My truck quit when my relay went out. I've replaced my pcm too. My pcm was fried by a senser that shorted in the fuel tank. My truck ran bad but it never quit when the pcm was bad. It would throw all kinds of false codes &stall out sometimes. When it stalled I could restart it & it would run ok. I think only a dealer can test the pcm.
Old 01-13-2007, 12:46 AM
thehawk789 thehawk789 is offline
thehawk789 is starting off with a positive reputation.
the dealer doesnt test the pcm, the dealer does tests around the pcm to determine what is going on.
heres what you need to do:
swap fuel pump relay with a similar one, see what happens.
if still no start- check terminals on fuel pump relay, you should have 2 powers and 2 grounds. The PCM switches to ground to activate the relay.
If you have 2 power terminals, you either have a bad ground or a bad pump.
IF you are good, you can jumper the power to the fuel pump with a jumper wire, it goes diagonally in the relay center, not to the one closest. You are going to want to figure out which is to the fuel pump and which is to the pcm.
I think that on a lot of trucks the fuel pump/sending unit is actualy grounded to the chassis.
BUT, since you arent getting power...
You could (for safteys sake) unplug pcm, unplug fuel sending unit, jumper both wires across, and that way for sure 1of them should send you power to the sending unit.
If you get power then, you either have a bad wire between the relay center and the pcm, or a bad pcm. If you are REALLY good, you could figure out which terminal on the relay center runs the wire to the pcm for the relay ground, then check it for continuity with an ohmmeter.
Old 01-15-2007, 11:15 AM
Quote:
Originally Posted by Wilber15
Hmmm, musta read that one out of AllData?? .... I don't have the schematics in front of me and i don't remember how the circuit is set up...
No, traced the circuit through the wiring diagram manual schematics.
HELP, need a PCM ending in QLJ4 Jmudweiser 1999 - 2003 7.3L Power Stroke Diesel 4 09-13-2016 05:02 PM
What does PCM Flashing do for me? Krazymaan 1999 - 2003 7.3L Power Stroke Diesel 2 08-24-2011 06:53 AM
PCM code redman84 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-08-2011 11:28 AM
PCM issues? sportsdad 1994.5 - 1997 7.3L Power Stroke Diesel 22 06-06-2010 07:38 PM
PCM number? gasgrunt88 1999 - 2003 7.3L Power Stroke Diesel 18 05-23-2009 10:00 PM
Tags
150, 2002, f150, ford, pcm, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
