OHV or SOHC
OHV or SOHC
I am looking at buting a 2000 Explorer sport with a 4.0L. Now for a really stupid question, how can I tell if its a OHV or a SOHC motor? The belt replacement sticker under the hood shows routing for both types of motors and does not say which one it is. Can you tell by the VIN number somehow?
Bash the 8th number is an x so I can rest assured it is the OHV motor. I have heard so many bad things about the timing chain cassettes on the SOHC motors I am paranoid. Up untill recently I had a 92 Explorer with 185,000 and experienced no major problems with it. I saw this 2000 sport model and my 16 yr old son really liked it so we are looking at it for him. I has 165,000 miles and just had a thermostat, water pump, intake manifold gaskets, battery and a 4 wheel brake job done to it, It seems that the owner ran upon some hard luck and lost his job so he wants to get rid of it. It is an auto tranny and I also understand that the tranny might be reaching it's life expectancy also, but hopefully not. Can you give me any insight as to any other problems I might be faced with in the not so distant future? Thanks for easing some of my paranoia.
Redboat
Redboat
Originally Posted by Redneck1465
The OHV engine is a pretty good engine as far as I can tell. My mom never had any problems really with hers.
Speaking (typing?) of OHC engines: My dad bought a brand new 1966 Pontiac Tempest with what I believe was the first US-made overhead cam engine. It was a 3.8 liter straight six, and it could rev up to 6500 rpm - quite impressive for those days. That was one strong motor, especially with the 4-bbl Rochester carburetor and 10.5:1 compression.
Interestingly, its neoprene timing belt was easy to change, far easier than the belts on OHC engines today. The belt cover was held on with three Phillips head screws and two metal clips, and took only a couple of minutes to remove. I "cheated" when I decided to replace it by cutting off the old one and pulling the new belt over the cam and crank gears. Probably not a good idea, but it never gave me any trouble.
Why can't timing belts be that easy to change now?
Frozen_Joker
12-05-2015 11:36 PM
leeesselman
08-20-2004 09:59 AM
wrcummings
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-30-2003 06:25 PM
