I bought Pro-Stripe from my local auto parts store. It was $9/ roll. 1 roll will do the whole truck. If I recall correctly is was met. beige color. It matches perfectly. It is a narrow stripe and a little wider stripe. I also did my wifes Sorento. She has the same color scheme as my truck. It is tough to do the F-150 because there are no body lines to follow. I had to do the driver side of the bed twice because the first time it was tilted. A string and some masking tape will help. Use the string as a measuring tool and then stick the tape where the string ends. Use the tape as a guide to keep it straight. I have seen the pinstripe at Auto Zone and Advance auto as well as Pep Boys. Good luck, if you need any more help just ask. Start at the front and go down the entire side of the truck. Go back and cut the seams for the doors and bed box later. Make sure you roll the edges of your stripe around the roll on the edge of the doors.
Many of the automotive painting supply retailers carry plenty of pinstriping tape.
__________________
Tim M.
'03 F350 CC Lariat 4X4 PSD
'06 F150 Supercrew 4X4 5.4
'54 F800 Big Job
'64 F100 short and wide
'96 GMC Topkick, '89 International 9670
