Bronco II Ford Bronco II
Draining the fuel tank
Old 01-11-2007, 04:08 PM
bones68's Avatar
bones68
bones68 is offline
Question Draining the fuel tank
'87 Bronco2 2.9l
I need to change the in-tank fuel pump.
I tried siphoning gas from the tank but its really hard to maneuver a hose into it. Is there an easy clean way to drain the gas tank?
Please let me know your ideas. Thanks..
Old 01-11-2007, 09:37 PM
97Centurion's Avatar
97Centurion
97Centurion is offline
Rub my Belly
What size hose are you using? I normally use a 3/8 fuel line to do my siphoning. I have it hooked up to an old fuel pump. Does a nice quick job. Sometimes a piece of garden hose will work better becuase it's a little stiffer and easier to push down in the tank.
A lot of times I'll skip the siphoning and just place a floor jack under the tank and let it down that way. It helps if there's and extra person to help steady the tank as you lower it.
Old 01-12-2007, 01:13 AM
madclone's Avatar
madclone
madclone is offline
A good advice - cut a hatch in the floor right above the tank unit assembly. This will give you instant access to the sending unit without any mess. Did it for mine 88 Bronco when took off the tank for repair. Now I know this was quite wise to do. When I had problems with my B2 recently, I found out that it was the sending unit. Thanks to the hatch it took me 15 min's to repair.
I could take pictures if you want. It looks neat.
As for draining - use a long hose (maybe 1.5-2 meters and 1 inch outer diameter). The trick is to push it inside the tank to the end and plug the hole with yor finger. Then pull out adequate amount of hose from the tank and place it as low as possible and release the finger - the gas will flow itself.
D from Russia
Old 01-12-2007, 06:24 AM
bones68's Avatar
bones68
bones68 is offline
Thanks for both you ideas. I really appreciate them.
Madclone if you could take some pics that would be very useful to see.
Old 01-12-2007, 07:07 AM
madclone's Avatar
madclone
madclone is offline
OK. I'll take a couple of shots this weekend
Old 01-12-2007, 10:04 PM
broncobillyII86's Avatar
broncobillyII86
broncobillyII86 is offline
cutting hole
Ya this is the way I'll go when I finally replace my sender...TR
Old 01-14-2007, 01:04 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
To drain gas tanks I use an old VW fuel pump connected to 3/8 line, just make the connection (I use a switch to avoid sparks and shorts) away from the tank. I remove the rubber filler neck hose completely.
Old 01-22-2007, 04:49 AM
madclone's Avatar
madclone
madclone is offline
Sorry for keeping you waiting. Here's the hatch I made.
scottperkins
1997 - 2003 F150
06-17-2016 10:12 AM
Ricohman
6.7L Power Stroke Diesel
06-19-2015 05:50 AM
sogath
05-12-2011 06:41 PM
Jermafenser
03-21-2007 06:51 PM
58 60 f-100
06-23-2004 11:37 PM
Quick Reply: Draining the fuel tank
