Draining the fuel tank - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 01-11-2007, 05:08 PM
bones68 bones68 is offline
bones68 is starting off with a positive reputation.
Question Draining the fuel tank
'87 Bronco2 2.9l
I need to change the in-tank fuel pump.
I tried siphoning gas from the tank but its really hard to maneuver a hose into it. Is there an easy clean way to drain the gas tank?
Please let me know your ideas. Thanks..
Old 01-11-2007, 10:37 PM
97Centurion's Avatar
97Centurion 97Centurion is offline
Rub my Belly
97Centurion is gaining momentum as a positive member of FTE.97Centurion is gaining momentum as a positive member of FTE.
What size hose are you using? I normally use a 3/8 fuel line to do my siphoning. I have it hooked up to an old fuel pump. Does a nice quick job. Sometimes a piece of garden hose will work better becuase it's a little stiffer and easier to push down in the tank.
A lot of times I'll skip the siphoning and just place a floor jack under the tank and let it down that way. It helps if there's and extra person to help steady the tank as you lower it.
Old 01-12-2007, 02:13 AM
madclone's Avatar
madclone madclone is offline
madclone is starting off with a positive reputation.
A good advice - cut a hatch in the floor right above the tank unit assembly. This will give you instant access to the sending unit without any mess. Did it for mine 88 Bronco when took off the tank for repair. Now I know this was quite wise to do. When I had problems with my B2 recently, I found out that it was the sending unit. Thanks to the hatch it took me 15 min's to repair.
I could take pictures if you want. It looks neat.
As for draining - use a long hose (maybe 1.5-2 meters and 1 inch outer diameter). The trick is to push it inside the tank to the end and plug the hole with yor finger. Then pull out adequate amount of hose from the tank and place it as low as possible and release the finger - the gas will flow itself.
D from Russia
Old 01-12-2007, 07:24 AM
Thanks for both you ideas. I really appreciate them.
Madclone if you could take some pics that would be very useful to see.
Old 01-12-2007, 08:07 AM
madclone's Avatar
OK. I'll take a couple of shots this weekend
Old 01-12-2007, 11:04 PM
broncobillyII86 broncobillyII86 is offline
broncobillyII86 is starting off with a positive reputation.
cutting hole
Ya this is the way I'll go when I finally replace my sender...TR
Old 01-14-2007, 02:04 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
To drain gas tanks I use an old VW fuel pump connected to 3/8 line, just make the connection (I use a switch to avoid sparks and shorts) away from the tank. I remove the rubber filler neck hose completely.
Old 01-22-2007, 05:49 AM
madclone's Avatar
Sorry for keeping you waiting. Here's the hatch I made.
Added Drain Plug to F150 gas tank scottperkins 1997 - 2003 F150 2 06-17-2016 11:12 AM
Gas tank debris issue shoogdoog 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 07-20-2015 06:10 PM
Can you drain the DFCM with a full tank? Ricohman 6.7L Power Stroke Diesel 4 06-19-2015 06:50 AM
Changing a fuel filler hose sogath 1973 - 1979 F-100 & Larger F-Series Trucks 14 05-12-2011 07:41 PM
Draining the fuel tank Karstonian 1999 - 2003 7.3L Power Stroke Diesel 2 08-28-2004 09:44 PM
Tags
07, 1974, 1989, bronco, drain, draining, early, f150, ford, fuel, gas, ii, ll, pump, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
