6 Mpg
6 Mpg
So I started up my truck lastnight like i said earlier only to find out that I burnt off almost a quarter tank when idling for 30 min to warm up. I've also been noticing that my MPG has been going down ever since the headgasket job. I was able to get 600km on one tank. (FIrst long drive after gaskets replaced) Now I'm lucky to get 300km. Problems that I know exist are sticky injectors and cracked y pipe. Possible turbo problems from what the dealer sais.
Anyone have any input if these problems could be the cause for so much diesel consumption?
The long idling is the worst thing you can do--it takes forever for one of these things to warm up (if it does at all) by idling. The turbo will have a direct affect on your fuel consumption as will the cracked y-pipe since it's feeding the turbo. The headgasket job should have improved your mileage if anything, since you resealed the combustion chambers.
it did improve for a bit. That first drive i was amazed. I can actually hear a hissing sound. Almost like there is gas escaping. I can hear it when i have my window rolled down. My turbo still surges too. No change noticible in rpms. The needle is steady and dosent jump around. So if i get that y-pipe fixed, do you think the surging will go away because there is enoughf pressure to feed the turbo? I hope so.
Originally Posted by Reidicus
Idling = less diesel used.
Where I work. We allow for a 10 minute warmup before going to full power on the equipment. If it is super cold (below 10) then 15 minutes. This is to get the oil thinned out and the transmissions a little warmth. Humans - can warm themselves. Yes diesels will not get warm in the cab until they are driven - sometimes 10 miles.
Originally Posted by jmcholden
Idled for 30 minutes and used 1/4 tank of fuel? That thing should be smoking like
Mount St. Helens?
Maybe the fuel gage is broke too!
Mount St. Helens?
Got an appointment on Monday to get the y-pipe replaced and to install the EGR exaust delete pipe as well. Should make for better turbo spool up times. Going to take apart the turbo, clean all the carbon build up and reassemble. Same with the EGR valve to make sure it is closed all the way.
While there, going to retorque the head studs to make sure they didnt come loose. Check for leaks and get the oil leak under the turbo fixed as well.
The sticking injectors, well dosent seem like such a big problem at the moment. So i'll leave them be.
After that, truck should be in perfect running condition.
Originally Posted by duffman77
How soon do you start driving it after a -20C start and it not being plugged in?
