p1127,1132, and 1158 codes.
If you look up the code discriptions, you will see the 1127 code is telling you there is a temperature problem. All the rest of the codes are reporting the same fault with differnt code#.
Question; is there a fault in the heater circuit of an Ox sensor, Is the sensor faulty etc.
A lean reference for the codes is to the fuel tables going to their lean setting as a short term fuel trim condition trying to correct for a rich condition.
It may or may not be an air leak at the inlet tract considering there is a 1127 code along with the others.
StuRagas
1983 - 2012 Ranger & B-Series
03-13-2008 03:26 PM
Imdok
10-11-2007 01:11 PM
exdriver
02-02-2007 06:53 PM
