Diesel fuel mixing with coolant problem - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-11-2007, 01:13 AM
rfmiles rfmiles is offline
rfmiles is starting off with a positive reputation.
Question Diesel fuel mixing with coolant problem
We have a 1999 F-250 with a 7.3 Powerstroke diesel. The diesel fuel is mixing in with the the engine coolant system and causing it come out the top of the reservor. We are loosing a lot of fuel. We are also having to shoot some ether in the breather to get it to start (not all the time). It runs very good going down the road. Would you know of any possible problems that would causes this?
Old 01-11-2007, 01:29 AM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Well of course we could have some ideas about how fuel gets into the coolant. Before I go any further, stop using ether to start the engine before you blow it up.
Old 01-11-2007, 06:36 AM
maevans's Avatar
maevans maevans is offline
maevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud of
I had the same problem, Mine was a leaking injector cup, Had it fixed under warranty.
Old 01-11-2007, 06:57 AM
Poohbear Poohbear is offline
Poohbear is starting off with a positive reputation.
I'll second the either comment I have been down that road.
Old 01-11-2007, 09:17 AM
How much trouble it is to replace the injector cups? Is there information such as exploded picture view, and instructions on this forum or even a link to fixing this problem ourselves? After you you mention the injector cups I did some research on that and found a similiar post, but no suggestions on how to fix it. They also mention that you couldn't tell exactly which injector was bad but would be able to tell which side of the engine it is on.
Old 01-11-2007, 06:52 PM
Just wondering if anybody knew where I might find some info on this repair. Also what about the tool as well. Is there a way to pin point which sleeve or even which side that is bad, so we would only have to do the least amount of work at a cheaper cost. Is there going to more involved that just buying the sleeves.
Thanks
Old 01-11-2007, 07:12 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
To isolate which bank has leaking cups remove the fuel feed lines from the filter bowl and pressurize the coolant tank. Whichever of the fuel lines starts bubbling and spitting is the side with leaky cups.
The Injector cups are a press fit with lock tight holding them in. The removal tool is a deal that goes on a slide hammer and the installation tool is basically a blank of an injector used to drive them in place.
Welcome to FTE!!!
Old 01-27-2007, 12:33 PM
Question
We pulled just 4 injectors on the drivers side. We can see coolant seeping through the sleeve on the 3rd one from firewall, but can't see in detailed yet, until we get it out.
Question I have is on the injector closest to the front of truck, the 'O' ring on the bottom has it's outer skin layer scraped off. I know this should be replaced, but is this 'O' ring holding the coolant from the fuel as well.
Also when we put Locktite on the sleeve to reseat it. Should we use just put it on the top layer or the top 2 layers of the sleeve. Should we use the strongest locktite also? We also don't have the tool to reseat it but we are planning on turning one out on the wooden lathe. Should we let this set up for any length of time before put the injector back in.
How do you post pixs in here, also?
Old 01-27-2007, 07:00 PM
*bump*bump*
Old 01-27-2007, 07:06 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
Ford calls it thread lock 620. PM me your email address and I can send you a pdf showing the 2 sufaces to put it on as well as the whole procedure.
Old 01-27-2007, 07:08 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
You can buy new injector o-ring kits, and i would replace all of the o-rings on the four that were removed. They aren't that expensive. And use Green Loctite on the injector cups.
Diluted engine Oil with Diesel jtec 6.0L Power Stroke Diesel 16 09-11-2014 04:58 PM
Fuel not reaching the Filter. LostinFord20 1994.5 - 1997 7.3L Power Stroke Diesel 17 01-23-2012 04:51 PM
orange coolant dryyyyy Ranger & B-Series 6 12-22-2011 12:11 PM
E85 Mix with Veggie oil??? fixin737s 1999 - 2003 7.3L Power Stroke Diesel 17 03-03-2011 06:18 AM
Oil in Coolant tomd 4 Cylinder Engines 2 01-28-2005 07:53 AM
Tags
coolant, diesel, mixing, problem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
