Engine codes
Engine codes
I have a 2000 ford f150 4.2 v6 and my service engine soon light came on. I took it to autozone and the code was 1309 it was a misfire. Does anyone have any idea how to fix this problem or what may cause it. Also my air bag light stays on does anybody have any idea how to fix that. Any help would be much appreciated thank you very much.
Your v6 has a cam position sensor up front. If it is out of adjustment or faulty a misfire can result. It's not peticular cylinder oriented because it involves all cylinders.
The missfire monitor is picking this up. Since it is not a cylinder at fault, it's reported as a 1309 for the CMP.
This is what happens when the codes are not interpeted correctly.
A Haynes book pages 6-11/12 has enough info to allow servicing.
Good luck on it.
Good luck on it.
on newer vehicles with crank position sensors there is an option you can do with a scan tool called "crankshaft variation learn" which filters out any variation in the reluctor wheel, because it can cause mysterious misfires. I dont think there is a cam variation learn, its probably a bad sensor or connection between the sensor and the PCM, or Ignition control module, which ever it connects to.
