Rear differential tag #'s
That;s what that means.
If there was an L in the ratio ( as in 3L55) then you would need it.
No L means an open diff.
Maybe read this?
http://www.ridgenet.net/~biesiade/Fordrears.html
Maybe read this?
Axle....
Thanks! I just got the old bearing out and new bearing/seal in. Waiting on the new axle to be delivered to the parts store for pick-up. I used the loan-a-tool program and had to put a total of $135 in deposits for 3 tools for removal and installation of the bearings. Glad I will get that back! I got two quarts of 80w-90 gear oil at the dealership while getting the new pinion shaft retainer bolt. I soaked the new bearing in the new gear oil. Is that two quarts going to be enough, I hope? The axle install should be same as removal only in reverse. Thank You everyone! This is my first axle job! You've all been great!
Lex2002
07-14-2013 09:41 PM
Hereford 350
03-07-2006 10:45 PM
FS88Bronco
04-05-2005 07:27 PM
