Y-block head bolt torque specs?
Old 07-10-2000, 11:41 AM
Frost's Avatar
Frost
Frost is offline
Old 07-11-2000, 07:26 PM
jeeps's Avatar
jeeps
jeeps is offline
I have a '60 F-100 with a '57 passenger car 312 in it. It has the Ecz-g heads and block. I removed the heads to inspect the condition of the internals, now its time to replace them. What is the torque specs and order for this engine? I assume it would be the same as the 292? Do you have to remove the rocker shaft to torque the end bolts? Thanks, I appreciate any help you can lend. By the way anyone have a 4bbl aluminum intake they want to part with?
Old 12-17-2005, 09:47 AM
trucktex941's Avatar
trucktex941
trucktex941 is offline
Y-Block head Bolt Torque Specs
According to my book on Y-Blocks the torque is as follows:
Tighten all bolts first to 55 lbs.-ft., then to 65 lbs.-ft., and finally to 75 lbs.-ft. You can find a diagram of the tightening rotation of the head bolts on page 75, FORD Y-Block book, author James Eickman, published by MBI Publsihing Company. Hope this helps.
Old 12-17-2005, 10:28 AM
trucktex941
Y-Block head bolt torque specs
http://www.ford-y-block.com/ Try this site for the correct information. I found it very helpful.
Old 12-17-2005, 07:29 PM
57_ford's Avatar
57_ford
57_ford is offline
Their are 3 different size head bolts. The 2 mid size bolts go on the end of the heads. That site in the last post read assembly errors.
Old 12-17-2005, 07:37 PM
Brian_B's Avatar
Brian_B
Brian_B is offline
If I am not mistaken, this is a thread where the question was asked in 2000 and answered in 2005.
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Roachfood
03-11-2002 10:21 PM
Quick Reply: Y-block head bolt torque specs?
