Gauge cluster question - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Old 01-10-2007, 10:35 AM
fjirousek fjirousek is offline
fjirousek is starting off with a positive reputation.
Hi all,
I have an 85' F-150 and my temp. gauge doesn't work. I replaced the sensor but still no go. I followed all of the wires and everything seems ok. I think I am going to try and replace the gauge cluster. Does anyone know of a good replacement option; from a different model year perhaps? Any ideas would be appreciated.
Thanks,
Fil
85' F-150
Inline 6
Old 01-10-2007, 08:13 PM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
ncfirefighter46 is starting off with a positive reputation.
you can order the replacement gauge factory from lmc truck. or find one in the j yard. i might can find one.
Old 01-11-2007, 09:50 AM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.
If you're replacimg it anyhow - I would go with an aftermarket, the mfg gauges are nortoriously inaccurate. Just my $.02.
Old 01-11-2007, 11:29 AM
Hi guys,
Thanks for the responses. I will take a look at the aftermarket options. Does anyone have a web address for LMC Trucks?
Thanks,
Fil
85' F-150
Inline 6
Old 01-11-2007, 04:11 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Quote:
Originally Posted by fjirousek
Hi guys,
Thanks,
Fil
85' F-150
Inline 6
Here's the web address. www.lmctruck.com
Old 01-11-2007, 04:36 PM
Max E Max E is offline
Max E is starting off with a positive reputation.
Did you ground the wire going to the senor to see if your gauge moved all the way over?? If you did ground it and it didn't move then the gauge is bad and you are going the right way. Make sure you have power to the gauge as sometime it is that simple
Max E.
Old 01-11-2007, 08:34 PM
Old Tired Rebel, thanks for the link. They've got some neat stuff on there! Max E, I did ground the sensor wire and the gauge didn't move. Thanks for the suggestion. I'll order the gauge and we'll see what happens!
Fil
85' F-150
Inline 6
Go Back   Ford Truck Enthusiasts Forums > >
Tags
85, cluster, f150, gauge, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
