Best grease for Ball Joints - Ford Truck Enthusiasts Forums
Old 01-09-2007, 09:17 PM
Palomino Palomino is offline
Palomino is starting off with a positive reputation.
Hello everyone,
Just had new ball joints installed recently that have grease fittings. The local store sells Mystik grease and Im wondering if Mystic JT-6 multipurpose grease is the correct grease to use. They also sell the Mystic JT-6 hi-temp grease and a SX-6 synthetic blend grease. Not sure which one would be the best ??
Any info appreciated,
Mike
Old 01-10-2007, 12:50 AM
beekermartin beekermartin is offline
beekermartin is starting off with a positive reputation.
Pretty much any automotive grease will be fine. You need hi temp grease for packing wheel bearings.
What kind of grease fot xrf ball joints? Poorboy04 6.0L Power Stroke Diesel 2 06-16-2015 12:40 PM
When to grease ball joints? holyspirit 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-03-2015 11:45 AM
Grease Iaff113 6.0L Power Stroke Diesel 7 01-15-2015 12:23 PM
U joint grease 6litrefan 1999 to 2016 Super Duty 17 04-26-2012 03:40 PM
Tie Rod Ball Joint etc Grease Question TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 15 03-11-2008 09:45 AM
Tags
97, ball, best, f150, ford, grease, greasing, high, joint, joints, lower, mystic, sx6, temperature, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
