engine knock
engine knock
Hi Everyone i have a 2002 lightning with 33000 miles and i am getting a knock from the engine(sounds like a big end) are they prone to this or is there a common type fault with it.Also we dont have any f150 main dealers in the country so if you have any thoughts on this they would be most welcome
Thanks paul
Thanks paul
My buddy has a Harley F150. and he had a ticking sound when ever it was idling. He let it go and he was driving down the road coming home from a trip one time and the engine misfired and started running like crap. It turns out that a spark plug wiggled itself loose and shot out of the side of the engine. I hear this is fairly common with the 5.4s. I do not know if this is your problem. you will have to be the judge of that, but if I were you I would check the spark plugs to make sure they are in securley.
One way to minimize your risk of launching a plug is to change your plugs with the engine cold, torquing the plugs to 12 - 15 foot pounds of torque.
As for the ticking noise, when a plug is working it's way loose, the sound can be mistaken for an exhaust leak.
p james, like the webmaster implied through his questions, we need a lot more info if we have any hope of helping you diagnose the problem.
Stewart
PS - What country are you in, and what octane of gas are you using?
I am in a similar situation where I have a ticking noise. when i bought the truck last september (2005), I was complaining about a noise that sounded similar to an exaust leak. i was told that i was hearing things. now i am replacing a head. i am absolutely livid. anybody have any suggestions?
My Lightning launched a plug almost two years ago.
One Timesert insert, a new plug, and a new COP and I was good to go.
http://www.timesert.com/html/sparkplugford.html
Stewart
Stewart
Ok. Well, those heads can have inserts put in them while they are on the truck. No need to pull the engine or pull the heads and especially no need to replace the head. Some people get scared off from inserts, but most of the aftermarket head companies like Patriot put those inserts in every spark plug hole to prevent blowout. My old Lightning had 2 inserts put in it. I did them both. Nothing you can't do in an afternoon with the Kit from Timesert.
Agreed...my brother blew a plug out in his Expedition/5.4. He installed an insert and replaced the COP, with the heads on the motor. He did this about 6 months ago and no problems thus far.
